Author Topic: 4 sidelights  (Read 6868 times)
Offline dubber36
Re: 4 sidelights
« Reply #20 on: 21 April 2010, 16:39 »
HIDs are a totally different kettle of fish.
Strictly speaking they need to be fitted in headlights designed for the job. Certainly not reflector lamps like Mk2 Golfs. They should have washers to prevent dirt on the lenses diverting the beam pattern and automatic levelling to keep the beam at the right angle, not only to compensate for load, but the undulations of the road as well.
The fact that the OP has fitted 5W parking light bulbs into his spot lights is no different to newer cars with them fitted into their main beam lamps. I think I may have already said that last bit. :smiley:
Offline X4MGS
  • VAG Parts SNOB!!!
Re: 4 sidelights
« Reply #21 on: 21 April 2010, 16:53 »
You are "ASSUMING" he has only fitted 5W bulbs...
TBH they look too bright for 5W for me..
At the end of the day it's his car, his MOT and his licence...
So do I really care... Not Really...
I'll not be rushing to fit any to mine...:rolleyes:
For More Info Click To See;
Offline dubber36
Re: 4 sidelights
« Reply #22 on: 21 April 2010, 17:13 »
Your right, I am assuming.
D'you know what, even before I read your last post I had thought Christ, is this thread still going. It only started with a bloke wanting to show us a mod he was quite pleased with. I'm board now.
Offline X4MGS
  • VAG Parts SNOB!!!
Re: 4 sidelights
« Reply #23 on: 21 April 2010, 17:28 »
Think my last post shows that I'm also bored with it....
Offline peaky83
Re: 4 sidelights
« Reply #24 on: 21 April 2010, 17:43 »
+1
Offline Dolly
Re: 4 sidelights
« Reply #25 on: 21 April 2010, 18:36 »
Yes headlamp washers...
I don't know exactly the reason why... all I know is that HID's are only meant to be fitted to cars that have A Headlight washer system fitted...
A member on the Audi S2 Forum is a MOT tester and he posted a link to the DVLA/MOT regulations and thats what it says...
I was really peed as I wanted to fit them to my MK2... after I fitted 'em to my S2...
Wrong
Optional Lamps Any additional position lamps are optional and are not included in the inspection.
Offline Dolly
Re: 4 sidelights
« Reply #26 on: 21 April 2010, 18:38 »
also wrong about head light washers, got jack to do with MOT i can guarantee you that.
Offline X4MGS
  • VAG Parts SNOB!!!
Re: 4 sidelights
« Reply #27 on: 21 April 2010, 20:39 »
Suggest you read this then....
http://www.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps
Quote
Aftermarket HID (Xenon) headlamps
Fact sheet: Aftermarket HID headlamps
December 2006
In the Department's view it is not legal to sell or use after market HID lighting kits, for converting conventional Halogen headlamps to HID Xenon. If a customer wants to convert his vehicle to Xenon HID he must purchase completely new Xenon HID headlamps. The reason for this is that the existing lens and reflector are designed around a Halogen filament bulb, working to very precise tolerances. If one places a HID "burner" (bulb) in the headlamp, the beam pattern will not be correct, there will be glare in some places and not enough light in other places within the beam pattern.
The following is the legal rationale:
The Road Vehicle Lighting Regulations 1989 regulate the situation in the UK.
Under these Regulations, HID/Gas Discharge/Xenon headlamps are not mentioned and therefore they are not permitted according to the strict letter of the law.
However new vehicles have HID headlamps. This is because they comply to European type approval Regulations. The UK cannot refuse to register a vehicle with a European type approval. These are to ECE Regulation 98 (for the HID headlamps which are tested on a rig in a laboratory) and ECE Regulation 48 (Lighting Installation on the vehicle).
For the after market, a used vehicle cannot obtain type approval because it is only applicable for new vehicles. However we feel that saying "HID is banned in the after market" would not be reasonable. Instead we should make analogies with new vehicles. It would be reasonable to require HID in the after market to meet the same safety standards as on new vehicles. The same level of safety should apply.
Therefore a HID headlamp unit sold in the after market should:
1. be type approved to ECE Regulation 98 as a component.
2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
3. Comply with RVLR as far as "use" is concerned.
In practice this means:
1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which are not legal.
In summary it is not permitted to convert an existing halogen headlamp unit for use with HID bulbs. The entire headlamp unit must be replaced with one designed and approved for use with HID bulbs and it must be installed in accordance with the rules stated above.
If you require any further information regarding the regulations covered by this fact sheet, please contact the DfT at the address below:
Transport Technology and Standards 6
Department for Transport
Zone 2/04
Great Minster House
76 Marsham Street
London
SW1P 4DR
Offline X4MGS
  • VAG Parts SNOB!!!
Re: 4 sidelights
« Reply #28 on: 21 April 2010, 20:46 »
Quote
I much prefer testing cars with HIDs fitted (in projector lenses), far clearer beam image!!
The criteria for headlamp testing is here:http://www.motuk.co.uk/manual_120.htm
Legally they can only be fitted to vehicles with headlamp washers and auto levelling- but thats not part of an MOT- thats for the police to decide.
Offline Dolly
Re: 4 sidelights
« Reply #29 on: 21 April 2010, 20:55 »
and i suggest you read my post... its got nothing to do with MOT, smart ass
