Author Topic: Vagcom wont connect to engine ecu but will connect to abs and airbag ecus..  (Read 4487 times)
Offline Cable
Thanks for the pics, but ive checked evrything  :sad: only thing left is to unplug and bridge the grey and grey/white wires to check if it reads the ecu then, but i dont know if this is safe?
Offline Cable
i bridged the connector and now it connects to my engine ecu, im guessing my immob box is at fault  :angry:
When i buy a new one do i need to get it with the key chip or can i code it usuing vagcom?
Thanks
you need to get an immob box with a matched chip, swap chip into your key, then match to your ecu with vag-com. if you get a box without a matched key only VW can add keys
« Last Edit: 15 April 2010, 14:50 by rubjonny »
Offline A8vgti
Hi, not sure if you have sorted this. I found your thread when trying to sort mine. I first checked mine with a ECU kit I knew worked. Still couldnt get the ethos to connect to the ECU. So then hunted around the fuse box (should of done this first) and found a small grey wire broken. Connected it back together and sure enough it was fixed. The only reason anyone has been behind the fuse box was to fit a immobiliser thats when it must have got broken.
Offline Cable
Yh my problem was the actual immobilizer box blocking access to my engine ecu, i got a new immob box and now it works fine.
