Author Topic: Remap  (Read 2424 times)
Offline Rhyso
Re: Remap
« Reply #10 on: 13 April 2010, 11:50 »
Its been like that since it happened, vw quaoted that it needs a new dash which I think is wrong
sounds like it just needs rematching to the clocks
I'd be asking for my money back from the tuner mind as I can't believe they have left a car in that condition  :angry:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Remap
« Reply #11 on: 13 April 2010, 12:05 »
That very bad service imo, some one with a cheap ebay too on no clue?
Sounds like a bad flash, or fuse 11.  Check fuse 11 and the connections if they seem ok then it could be a bad flash.
Get the ecu posted out to me with the return P&P and I will fix it for your mate.
Nick
 01455 617233
Offline Voodoo-Music
Re: Remap
« Reply #12 on: 13 April 2010, 15:30 »
if i needs matched to the clocks it wont be done with vag com, it needs vag tacho doesnt it ?
Offline Rhyso
Re: Remap
« Reply #13 on: 13 April 2010, 15:31 »
VAGCOM  :wink:
When doing Dai's conversion we used VAGCOM to get the two talking to each other
aRD intially did the re-coding but we then used VAGCOM to pair them back up once in the car
Offline EuanGtTdi
Re: Remap
« Reply #14 on: 14 April 2010, 17:37 »
got some news back, they were putting a 150bhp map onto the one 130 ecu! it started and took it a run but now it starts then cuts out! and on the dials or clocks its coming up something DHF or DF on one of the computer screens and no millage and a couple of warning lights aswel like temperture, airbag!
any help or ideas?
Offline RTechUK
Re: Remap
« Reply #15 on: 14 April 2010, 17:47 »
any help or ideas?
Write a stock map back to the car, job done. I should write back to the ecu fine if not, they need to ground the eprom and write the ecu in boost mode.
I have all the stock files to hand if needed.
Nick
 01455 617233
Offline EuanGtTdi
Re: Remap
« Reply #16 on: 14 April 2010, 17:52 »
okay so by this do you mean you can send them over email or something to this boys laptop for him to to take them from the laptop hes using and put it back on thro the port?
Thank Euan
Offline RTechUK
Re: Remap
« Reply #17 on: 15 April 2010, 12:12 »
Thank Euan
I will need all the number off the ecu, the one ending 019** and the one starting 0218********  post them up with your email and i will send you a files.
Nick
 01455 617233
Offline AlanD
  • MK5 2.0T 16v
Re: Remap
« Reply #18 on: 15 April 2010, 13:05 »
Nick saves the day, again :cool:
