Author Topic: weitec  (Read 3096 times)
Offline Steve_PD
Re: weitec
« Reply #10 on: 12 April 2010, 19:05 »
if you think standard suspension is harsh do not even think about coilovers!!!!
Offline bobreece
Re: weitec
« Reply #11 on: 12 April 2010, 19:18 »
what am i gone do then need the car lower on 18s as it looks to high. dont mind stiffer and bit harsher but the ones i have now the standard set up is rubbish
Offline bobreece
Re: weitec
« Reply #12 on: 12 April 2010, 19:28 »
should i go for springs and shocks rather than coilovers?
Offline Steve_PD
Re: weitec
« Reply #13 on: 12 April 2010, 19:30 »
yes springs and shock, what ever you go for will be stiffer and harsher than the standard setup
Rhyso rates his Eibach springs and bilstein shocks, as does Rich with Eibach springs and shocks. also read good things about weitec springs and shocks all depends on how much you want to spend and what sort of drop your after
Offline bobreece
Re: weitec
« Reply #14 on: 12 April 2010, 19:49 »
looking for 40mm drop its already 25mm as standard so think 40mm should be fine and have not got funds for new arb and stuff so carnt really go lower than that got maybe £300
Offline bobreece
Re: weitec
« Reply #15 on: 12 April 2010, 20:49 »
would like some guys to tell me what there running how they find them compared to standarded
Offline richw911
Re: weitec
« Reply #16 on: 12 April 2010, 20:50 »
As steve says eibach shocks and springs here and only a but harder than the standard set up - only a 30mm drop though  :smiley:
Offline Rhyso
Re: weitec
« Reply #17 on: 12 April 2010, 20:55 »
standard is like an air sprung mattress
Bilstein B4 and Eibach springs are slightly firmer but not bone shaking
Offline bobreece
Re: weitec
« Reply #18 on: 13 April 2010, 01:31 »
is adjustable damping any good?
Offline Damian @ DPM
  • DPM Performance
Re: weitec
« Reply #19 on: 13 April 2010, 10:18 »
Personally I think it's only needed if you do a lot of track days. For everyday road use set damping is fine.
Damian @ DPM Performance
DPM PERFORMANCE
The premier online suspension and handling specialists!
www.dpmperformance.co.uk
0191 2816844
sales@dpmperformance.co.uk
http://www.facebook.com/pages/DPM-Performance/208281640681
