Author Topic: shell v power  (Read 8412 times)
Offline mossy1969
shell v power
« on: 11 April 2010, 17:22 »
just  a quick one can you really tell the differance between shell v power and normal unleaded ,and does it improve performance,and mpg
Offline ub7rm
Re: shell v power
« Reply #1 on: 11 April 2010, 18:36 »
Rather than do this topic, again, might be worth doing a search  :smiley:
2020 BMW 128ti
2017 Golf GTD Estate
Offline Hurdy
Re: shell v power
« Reply #2 on: 11 April 2010, 19:05 »
Yes, for sure....if you are tuned :smiley:
Seat Leon Cupra Black 290 DSG
Offline Gene Hunt.
Re: shell v power
« Reply #3 on: 11 April 2010, 19:25 »
...........& it's getting fcuking expensive  :cry:.
Candy White ED35.
Offline TagnuT
  • Edition 30
Re: shell v power
« Reply #4 on: 11 April 2010, 19:31 »
Tesco 99  :grin:
Bye Bye Edition 30
Offline Spaced
Re: shell v power
« Reply #5 on: 11 April 2010, 19:47 »
Can't say that it improves MPG, but it feels like you have an extra 1000rpm. But at £1.26 per litre I am on the normal shell unleaded for the moment with no real ill effects.
Loyal owner since 2005, done with remapping, I drive a Golf not a Veyron. (hypocrite)
Offline richw911
Re: shell v power
« Reply #6 on: 11 April 2010, 20:06 »
+1  :smiley:
Offline ub7rm
Re: shell v power
« Reply #7 on: 11 April 2010, 21:05 »
Me too, can't say I've noticed any difference to mpg but there is something missing from the top end.  Since I spend most of the time at the lower end of the rev range I'll live with it and save the goodstuff for when I know I'm going to have some fun ...
2020 BMW 128ti
Offline stealthwolf
Re: shell v power
« Reply #8 on: 11 April 2010, 23:24 »
Mk5 Golf gti will run on 95/99/102 ron but benefits from 98 ron or higher as recommended on the sticker on the inside of the fuel filler cap. Anything below 98 ron will basically lead to less mpg and less power. How much? I don't know.
Offline ub7rm
Re: shell v power
« Reply #9 on: 12 April 2010, 07:01 »
As expected I have noticed a difference in power delivery at the top end, maybe not quite as eager as she used to be on 98.
MPG wise I have honestly not noticed any difference at all, if anything a slight improvement but this might have more to do with the weather than anything else as its gotten a lot warmer in the last couple of days.
I think the MPG benefit will depend on the type of journey you do.  High octane is said to be better as it allows the engine to stay in lean mode for longer, but the engine will only go into lean mode if its at a steady speed and increase in power is not being demanded - i.e. cruising.
My commute is mostly town traffic and a little blast on a dual carriageway; so I doubt it gets the chance to go into lean mode anyway which is probably why my MPG hasn't really changed.  Others doing motorway journeys may not agree ...
2020 BMW 128ti
