Author Topic: madmanluke's supercharged mk2 VR  (Read 379571 times)
Offline madmanluke
Re: madmanluke's supercharged mk2 VR
« Reply #420 on: 04 October 2011, 21:34 »
sounds good tech. we do it quite a bit now - my brother has a vectra at pretty much touring spec right now (a lot of genuine 90's parts from the real things) and we use that round the track. So much fun! Its not an actually track but more time trials around coned sprint circuits up on north weald air field. Its a great crack as you get loads of go's as its not overly busy!
Just want it on the road though, let alone the track
Offline Toby
  • Car - less
« Reply #421 on: 04 October 2011, 21:43 »
looks f**kin sick bro!! bet you cant wait for that 1st drive  :cool:
Currently down under
Offline madmanluke
« Reply #422 on: 05 October 2011, 11:51 »
You bet I can't. Just need to get a long list of things ploughed out now. Bit restricted this week as I'm not in the country but hopefully after that I can crack on.
Just sitting in heathrow T5 waiting for my flight out and have come up with the following list of all the stuff I need to do before it gets back on the road!
To Buy List
Exhaust down-pipe gasket
New front bearings
New tyres t1r's
Anti freeze
hand brake cables mk3 or mk2?
VHT paint
Exhaust dowpipe bolts
Water pipe for washer jets
Things to hold heat shield on
13 mm drill for pucks
To do:
Wheel bearing/driveshafts
Run brake lines
re-paint front calipers
Clean shocks with wire brush + refresh
Find drive shaft plates
Horn
Fog light right side
Slam panel - mod and paint
Radiator wires
Main use box live - needed?
Brake lines - flare and run
Head lamp - 90 degree pins on right side
Side lights - put bullet connectors on
Boot popper cable solder
Rear beam bolts - tighten!
Insure.
MOT.
Tax.
Drive.
Offline madmanluke
« Reply #423 on: 12 October 2011, 18:58 »
Loom modding on my hotel room floor while on a business trip to Germany.
Offline Toby
  • Car - less
« Reply #424 on: 12 October 2011, 19:07 »
now thats dedication  :grin:
Offline travisreeve
« Reply #425 on: 12 October 2011, 21:21 »
^^^^^^ BRILLIANT  :grin:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #426 on: 12 October 2011, 21:37 »
love it mate did it need much work ??
Offline madmanluke
« Reply #427 on: 12 October 2011, 23:54 »
Still working on it mate hah, I got pulled away by clients so haven't got back to finish it yet. Looks like I just need to remove all the rad fan wiring and do some relocating of stuff then just wrap it enough to get it back in the suitcase with out it getting tangled. Then completely wrap it when I get home for saturday.
Offline VR6_Wherry
« Reply #428 on: 13 October 2011, 09:28 »
You better hope none of the wires start showing through the bag they may think you're a terrorist!!
Good luck with getting through customs on the way back!  :grin: :grin:
Offline madmanluke
« Reply #429 on: 13 October 2011, 16:16 »
might need it, haha. Did think about that when i got on the plane here haha
