Author Topic: Clocks  (Read 1305 times)
Offline JezGTI
Clocks
« on: 16 November 2004, 23:06 »
I'm slowly sorting out the niggles with my MK2 gti H reg (1991) 8v.  I'm now trying to work out why the mfa isn't working fully, I get the time, trip time & outside temp (i used to get oil temp too but that just went off one day?).  Any ideas for fixing it or do I have to get hold of a replacement from ebay or similar?
Rain
Re: Clocks
« Reply #1 on: 16 November 2004, 23:49 »
Re: Clocks
« Reply #2 on: 17 November 2004, 10:21 »
The MPG reading uses a vacuum connection round the back of the clocks which runs from a vacuum pipe to the inlet manifold somewhere.  The oil temp runs from a sensor which is screwed into the oil filter housing, you should have 2 sensors screwed into it, the one closest to the engine block is the MFA I think!
Offline JezGTI
Re: Clocks
« Reply #3 on: 17 November 2004, 16:54 »
Cheers, does the vacuum pipe work with any of the MFA functions also i.e. trip mileage?
Re: Clocks
« Reply #4 on: 18 November 2004, 11:03 »
MPG is worked out using vacuum, speed and revs I believe.
