Author Topic: Few lightened flywheel questions - FITTED  (Read 20980 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Few lightened flywheel questions - FITTED
« Reply #80 on: 10 May 2011, 10:45 »
Just use a new set of standard flywheel bolts afaik.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #81 on: 10 May 2011, 10:49 »
can somebody give me the contact deets for the dude on CCGT and how much it costs to do ?
i am using a 16v box and flywheel in my conversion, which is a BAM engine.. im guessing this is worth doing ??
Not no ordinary GTI....
www.mixcloud.com/kells/
« Reply #82 on: 10 May 2011, 11:14 »
yep but use a little loctite on them.
« Reply #83 on: 10 May 2011, 13:11 »
Contact 'Hotgolf' over on CGTI. I think he charges £69 to lighten and balance an ABF flywheel which you'd have to supply.
Offline sharki786
  • GOT BOOST??
« Reply #84 on: 10 May 2011, 15:45 »
PM'ed
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline leigh_harty
  • Audi AGU
« Reply #85 on: 10 May 2011, 17:47 »
When i had mine done it cost £45 iirc for lightening and balancing from a machine shop...
But they would only do it whilst bolted to a crank!
Dont lose your dinosaur!
Offline Ess_Three
« Reply #86 on: 11 May 2011, 07:20 »
Hardly a fair comparison then, is it?
Marts price includes return postage, and quick turn around.
If you don't want your crank doing...it's a perfect option.
..but gaining motorcycles.
Offline leigh_harty
  • Audi AGU
« Reply #87 on: 11 May 2011, 17:37 »
My point is, it may be worth going to your local machine shop... I could pop down on my work breaks
Plus when i had mine done i never knew about this guy... and I probably would have used him.
« Reply #88 on: 11 May 2011, 19:15 »
I don't think id be happy having some random machine shop playing around with my flywheel because if it isn't done correctly you're looking at some serious engine and gearbox damage.
Id much rather pay a few quid more and give it to someone that has experience with flywheels on  a daily basis.
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
« Reply #89 on: 12 May 2011, 13:35 »
easy enough to machine down on a lathe but you also need balancing equipment to re balance it after cutting :)
I had an 020 flywheel done by hotgolf for my mk1, top bloke and quality job. When I need to do the clutch on the mk3 I'll be sending an 02A one to be done :)
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
