Author Topic: 1.8t possible turbo problem  (Read 999 times)
Offline mike_j_b
« on: 29 March 2010, 19:07 »
hey guys . just got a newsouth performance boost gauge fitted on my 1.8t (aum) and am pretty unsure of the results . pre 3000 rpm it appears to be boosting around 9psi but as soon as it hits 3000rpm bam the boost drops to around 6 psi . ? any ideas ? Is does this in any gear ecu is standard and vagcom shows no faults. Any help or advice is much appreciated as i dont know anyone else with an aum engine to compare with
Offline richw911
Re: 1.8t possible turbo problem
« Reply #1 on: 29 March 2010, 19:17 »
I would say its normal for a standard 1.8t  :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 29 March 2010, 23:33 »
get some logs of blocks 115 and 118 with vagcom if you're concerned.. 6 - 7 psi held is normal.
