Author Topic: oil on spark plug leads  (Read 2956 times)
Re: oil on spark plug leads
« Reply #10 on: 29 March 2010, 10:04 »
Failed cam cover gasket.
+2 easy enough to sort.
Offline gtiscott
« Reply #11 on: 29 March 2010, 12:15 »
Anyone have a guide to doing this?
VW BUSH
« Reply #12 on: 29 March 2010, 13:28 »
Offline VR6-Joe
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Dan34
  • VTEC Powerzzzz
Offline gtiscott
« Reply #16 on: 29 March 2010, 14:56 »
Ok it's the gasket... Lol. Does anyone have a guide to doing it for a novice
Christo77
« Reply #17 on: 29 March 2010, 16:34 »
Hehe..hi ole chap, well if you think your not up to doing it then get your mechanic man on to it..although i'm a bit surprised he didn't spot the problem himself! must be a fair bit of oil down the front of the engine if that's the case..
Anyway, just take a look at the cam cover..you'll soon see it's a doddle,
On the left, unclip the cam belt cover and remove or position away from cam cover end.
On the top back of cam cover unbolt the throttle body brackets.
Remove breather pipes off pressure regulator (top left on cam cover) undo the cam cover retaining bolts, on the right hand end two of the bolts incorporate a cabling/pipe retainer bracket..cover should now come off, if it's a bit stuck give it a few taps with a wooden mallet or similar..
Clean the mating surfaces/remove any bits of gasket and have a general wipe around and inside the cam cover.
Refitting = removal procedure in reverse.. just make sure the new gasket stays in place when manouvering cam cover back onto the engine.
Progressively tighten the cover bolts down working in a spiral pattern until all torqued up to 10nm..
It sounds more complicated than it is..if your going to do it though detatch coil lead and battery lead as precautions..
See what you think anyway..
Offline gtiscott
« Reply #18 on: 29 March 2010, 19:34 »
sounds easy  :laugh:, will give it a go when the rain eventually stops
Christo77
« Reply #19 on: 29 March 2010, 20:44 »
Go for it  :wink:   and yep same with mine, got little jobs to do but just as i get my tools together another dark cloud comes looming.. soon though eh,
