Author Topic: oil on spark plug leads  (Read 2965 times)
Offline gtiscott
« on: 28 March 2010, 17:41 »
when pulling out spark plug leads i noticed they are quite oily, is this a bad sign,also the end of one semed a bit melted..... :sad:.    .  how do i clean oil out of this area?. going to change both anyway(plugs and leads)  but never change plugs myself on this car but have done om my wifes zafira...is it the same tool size(16mm)
cheers
scott
Christo77
Re: oil on spark plug leads
« Reply #1 on: 28 March 2010, 18:53 »
Sounds like either your running a bit of a rich mixture or some oil is getting up to the plugs..  are you burning any oil?  and what's the air intake side of things like..blocked airfilter? need changing etc..
The plugs should look a browny grey/white ish colour around the electrodes but not wet.. if they're black and sooty looking that's likely an over rich mixture.. if they're definitely wet then could be oil, although i tend to think that's less likely on these engines unless severely neglegted..
Christo
Offline gtiscott
« Reply #2 on: 28 March 2010, 19:10 »
Didnt take plugs out only leads and leads were oily
Christo77
« Reply #3 on: 28 March 2010, 19:23 »
Just the leads.. missinterpreted your post sorry,
I guess then unless it's usual grime and grease or wd40 best just run the engine and see what or if anything is blowing/leaking/getting onto the leads..
Also that everything else is behaving normally, engine warm up/running temp, no loss of oil etc..
Offline gtiscott
« Reply #4 on: 28 March 2010, 20:15 »
i don't lose any oil really... engine does look a bit oily at bits but always has done and mechanic has always said it was fine, runs sweetly too.
scott
Christo77
« Reply #5 on: 28 March 2010, 20:35 »
With mine the dipstick holder cartridge area gets kinda dirtied up, i assume by airflow and heat grime from the alternator and belts etc..that's pretty normal but if you have any doubts about the leads then maybe replace them.. sounds like it's basically ok.
Offline gtiscott
« Reply #6 on: 28 March 2010, 20:40 »
i think it prob is ok but going to do a service so will change anyway, cant beleive the price of leads though.  thanks for the help mate
scott
Christo77
« Reply #7 on: 28 March 2010, 20:47 »
No probs cheers..
Also have a look on vwspares site (AVS car parts) the beru one's apparently are ok quality wise and not too expensive..
Offline AudiA8Quattro
« Reply #8 on: 28 March 2010, 21:46 »
Failed cam cover gasket.
Offline gtiscott
« Reply #9 on: 29 March 2010, 08:16 »
^ easy fix?
