Author Topic: MK1 Rewire Help  (Read 24776 times)
Offline raferackstraw
Re: MK1 Rewire Help
« Reply #30 on: 10 May 2010, 23:09 »
possible short between sender wires? or sender itself? or wires wrong way round?
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Re: MK1 Rewire Help
« Reply #31 on: 11 May 2010, 08:48 »
disconnect the level sensor, if that helps its shot. if not the purple wire is shorted to ground somewhere
Offline SoundillusioN
Re: MK1 Rewire Help
« Reply #32 on: 12 May 2010, 09:53 »
Thanks guys, will look at this tonight.  :smiley:
Re: MK1 Rewire Help
« Reply #33 on: 25 May 2010, 19:24 »
Disconnected level sensor...... gauge went down to empty... so sender is shot!... probably the result of a 5 year empty tank!  :sad:
Offline richandhazel
Re: MK1 Rewire Help
« Reply #34 on: 25 May 2010, 19:58 »
Mentioned it in your other thread but it would be well worth removing it and having a look. Might just be stuck and/or need a clean up. Worth looking at before you rush out and buy a replacement.
