Author Topic: Gear shift weight linkge bar?  (Read 4099 times)
Re: Gear shift weight linkge bar?
« Reply #10 on: 15 November 2004, 11:03 »
I find that my gears don't crunch as much after I fitted one, also made selecting first much easier!
I have one of these spare if anyones interested, found a MK3 in me local scrappy :)
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #11 on: 15 November 2004, 12:44 »
Thanks Gambit!
I'll try it and I'll change the gear box oil and see if there is a difference!
Once i sort the flat spot and oil leak i may start to enjoy it :)
Offline JezGTI
« Reply #12 on: 16 November 2004, 11:39 »
Sounds like a good idea, how do I fit it?
« Reply #13 on: 16 November 2004, 11:55 »
easy, open the bonnet and look in your engine bay.  Theres a long metal rod bent at each end helds on with 2 split pins.  Not the shorter ones with plastic ends, its a metal rod.
Take that off, replace with MK3 weighted rod, which is the same item but with a big chunk of metal in the middle!  Can do the same thing by strapping a chunk of lead to your existing rod, wont look as nice though ;)
Offline Deefadog
« Reply #14 on: 16 November 2004, 12:53 »
I might take a look in my old fishing box and see if i got a large weight in there, worth a go i guessb :)
Offline Gambit
« Reply #15 on: 16 November 2004, 13:23 »
just buy the proper item cheapskate!! :P
Offline JezGTI
« Reply #16 on: 16 November 2004, 13:30 »
Is there anywhere on the net where you can type in a VAG part number and get a description (I'm trying to confirm this part before buying).
« Reply #17 on: 16 November 2004, 13:43 »
Gimmi the number and I'll check on my ETKA software
Offline JezGTI
« Reply #18 on: 16 November 2004, 14:41 »
1HO 711 183 I think.  So what's ETKA software then??
« Reply #19 on: 16 November 2004, 15:09 »
Thats the weighted shift rod :) (its 1H0 711 183 btw ;))
ETKA is the software you see the VW parts monkeys using, has diagrams etc.  Can be found on emule :)
