Author Topic: Oil pouring out!!! help  (Read 3134 times)
Offline Deefadog
  • Mk2 16V (November 89)
Re: Oil pouring out!!! help
« Reply #10 on: 15 November 2004, 13:22 »
Oil is already drained :)
Thanks I'll let you know how it goes! I feel a few knuckles coming off with this job though :) lol
Offline Deefadog
« Reply #11 on: 15 November 2004, 20:52 »
Just a thought! Is it posible for the oil to be leaking from the breather?
Rain
« Reply #12 on: 15 November 2004, 21:31 »
if you mean the gromet and breather on the top of the rocker cover then yes oil can leak there if the breather is loose or the gromet has had it. try some black tap around the breather to give it a tighter fit make sure you clean any oil off the breather first   ;)
Offline Deefadog
« Reply #13 on: 15 November 2004, 22:03 »
Yes the breather which is tothe left,next to the oil cooler, I mean the actual bit that is attached to the engine, not where the breather hose goes over!
I don't want to replace the oil cooler bracket gasket and find it the breather housing! :(
Offline Gambit
« Reply #14 on: 16 November 2004, 09:19 »
doubt it'd be the breather as there is naff all oil flow there.
Offline Deefadog
« Reply #15 on: 16 November 2004, 11:02 »
Ok great, just a thought that's all as it's bolted next the oil cooler bracket and the oil is coming from there and i though it might be that instead, i don't want to renew the oil cooler bracket gasket and find it not that! :)
Offline Deefadog
« Reply #16 on: 01 December 2004, 08:51 »
Thought i'd finish this thread off!
Job done! :) it was the gasket.
No more oil leaks :) phew!!
