Author Topic: Early door glass dimensions.  (Read 2967 times)
VeeDubGTI16v
Re: Early door glass dimensions.
« Reply #10 on: 25 March 2010, 14:52 »
wouldn't you be better tracing round a window and sending them a template? there will be quite a few angles etc to measure if they want dims
Offline Horney
« Reply #11 on: 25 March 2010, 14:59 »
If you came round you would have one out of the car to use as a template!  When i get home tonight i will measure it up for you.
Cheers, are you free in the evenings around 5pm. I was thinking of popping round on my way home from work one night next week. I've got the baffles and a plan from Mark for you as well.
Well has the big window template and the small window is just the same as the big window with a bit chopped off. From what I can see the bit chopped off is parallel with the other end so it should be fine (fingers crossed!).
Nick
VeeDubGTI16v
« Reply #12 on: 25 March 2010, 15:04 »
i was thinking that, but are you sure the window isn't a bit taller than the qtr light?
Offline Horney
« Reply #13 on: 25 March 2010, 15:20 »
Yeah it is but the guy already has the big window template liek I said. The glass is the same size and shape except for having the end cut off.
nick
VeeDubGTI16v
« Reply #14 on: 25 March 2010, 15:24 »
but the qtr glass doesn't fit into the window runner like on a big window, thats where i think the size might be a bit different.
happy to be wrong though! at least you will be cutting material off if i'm right, its harder to add material  :grin:
Offline Horney
« Reply #15 on: 25 March 2010, 15:26 »
Ah I know what you mean now. I'm getting the 1/4 lights off Jon, it's just the big window the chap on CGTI is doing for me :cool:
nick
Offline Horney
« Reply #16 on: 25 March 2010, 15:34 »
So as per above the main window is the same shape and dimmensions as the big window version until the point the "end" is chopped off. The 1/4 light is not as deep as as you pointed out it only sits in the rubbers.
nick
Offline shaolindan
« Reply #17 on: 27 March 2010, 16:30 »
nick
I hope you are only eating salads, driving without any passengers and most importantly driving naked?!
Golf GTi 8v mk2 1990
Coilovers, BBS RA, K&N Induction Kit...
Offline Horney
« Reply #18 on: 27 March 2010, 17:37 »
Salads? As if!
Nick
