Author Topic: Need some help car playing up  (Read 2759 times)
Offline topher
  • Administrator
  • fully functioning
Re: Need some help car playing up
« Reply #10 on: 23 March 2010, 22:41 »
yeah sometimes if you leave it 30 seconds or so it sorts itself out
someone down by you is bound to have a smoke/pressure tester, i think most places charge 20 - 30 quid to do it. You can also make your own with a bit of ingenuity and a bicycle pump. If you get stuck we have one.
Offline ian007miles
« Reply #11 on: 23 March 2010, 22:53 »
if there is a boost leak will it show up a fault code?
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline gti_shaun
« Reply #12 on: 23 March 2010, 23:11 »
ive got that intercooler, i found a few imperfections in the welds on mine that would have deffo leaked as i blocked one side off and blew down it in water and it leaded, i gave all my pipes to a mate and he re-welded them all to be sure on rest.
Offline ian007miles
« Reply #13 on: 23 March 2010, 23:21 »
I checked all the welds this afternoon wen I was checking for boost leaks and they all looked fine. Some thing in my head is telling me n75 and when I was at r-tech last Wednesday for all my up grades nick said that the n75 won't last much longer and I should change it so maybe it's naffed but ille get it checked for fault codes first
Offline gti_shaun
« Reply #14 on: 23 March 2010, 23:27 »
maybe MAF playing up? deffo need get codes checked and go from there
Offline ian007miles
« Reply #15 on: 23 March 2010, 23:35 »
The other thing is it doesn't do it all the time because I booted it earlyer on the way back from the inlaws and it went like it suposed to and the as soon as I stopes at the lights and set off again in started playing up again, so shorly if it was a boost leak it would play up every time I put my foot down?
Offline topher
  • Administrator
  • fully functioning
« Reply #16 on: 23 March 2010, 23:35 »
2:1 odds its 17705 with an outside chance of 17965 at 5:1 :laugh:
if you have vagcom, and a modified 1.8t, become familiar with those two codes!
Offline topher
  • Administrator
  • fully functioning
« Reply #17 on: 23 March 2010, 23:36 »
and yep, even after that description i'd be looking for leaks first.
Offline ian007miles
« Reply #18 on: 23 March 2010, 23:40 »
Ok mate ille have another look at all the pipes tomoro to be on the safe side and what are the two fault codes u listed?
Offline ian007miles
« Reply #19 on: 24 March 2010, 16:20 »
Just had the car checked over by amd Essex and there was no fault codes and no boost leaks, so time for another trip up to r-tech to see if they can solve my problem
