Author Topic: Standard or Uprated clutch? Recommendations?  (Read 7971 times)
Offline golfmk4owner
Re: Standard or Uprated clutch? Recommendations?
« Reply #10 on: 21 March 2010, 16:21 »
Well i believe the 130 and 150 clutch is the same (?), which tells me theres room for tolerance, but to what extent?
I think correct driving can make a standard clutch work fine, but then who wants to drive a remap correctly? :P  :evil:
2005 GT TDI 140 - Standard as F@k
Offline Rhyso
« Reply #11 on: 21 March 2010, 16:22 »
they are the same - both 240mm diameter which means we can't fit the G60 / VR6 setup which is considerably cheaper  :sad:
Mine lasted 2K after it was first remapped  :lipsrsealed:
« Reply #12 on: 21 March 2010, 16:28 »
2k?!
Now im scared to fit a standard clutch... hmmm
Offline Steve_PD
« Reply #13 on: 21 March 2010, 18:42 »
Standard clutch will take a remapped, it may wear out quicker than a upgraded one. may only last 80k instead of 100+
it only starts slipping once its worn down to the rivets.
Rhyso's must have been worn bad anyway and wouldn't have lasted much longer on a standard map
« Reply #14 on: 21 March 2010, 18:44 »
Excellent info guys :)
Offline Rhyso
« Reply #15 on: 21 March 2010, 18:48 »
It's living in the valleys boyo  :sad:
« Reply #16 on: 21 March 2010, 19:12 »
Lol whats living in the valleys got to do with it? Steep hills?
Offline Rhyso
« Reply #17 on: 21 March 2010, 19:13 »
yep - steep hills and booting it in 6th up them when you really should change down a gear  :lipsrsealed:
« Reply #18 on: 21 March 2010, 19:15 »
Lol, 6th gear up a hill? Chug chug chug  :grin:
Offline Rhyso
« Reply #19 on: 21 March 2010, 19:16 »
Not with Derv power  :evil:
