Author Topic: Kph to mph in the display??  (Read 41265 times)
Offline p3eps
Re: Kph to mph in the display??
« Reply #30 on: 03 April 2010, 18:32 »
Daft question maybe.
Wouldn't changing to the U.S setting mean that mpg will be worked out for U.S gallons?
Yeah, but you can choose UK Gallons on the Highline display... and also change the Temp to Celcius and Time back to 24hour.
My next question then... how do I disable the seatbelt warning?  I don't mind it beeping if my keys are in the ignition when the door is open.  Its not something I do very often.
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline tezyuk
« Reply #31 on: 03 April 2010, 20:16 »
Carnt remember was just playing about
with vcds I think in the instrument module
I unticked bit 2 in byte 1 which was seat belt
I'll check tomorrow and post up.....
Mk7 golf gti performance pack
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #32 on: 03 April 2010, 20:20 »
You guys with vcds can you have a look next time your fiddling to see if there is a way of switching off my xenons + rear lights that are on all the time?
Garage:
35+ years of GTI ownership.
Offline tezyuk
« Reply #33 on: 03 April 2010, 20:21 »
Have a look on this link scroll down
to instrument got all the codes etc
http://en.openobd.org/vw/golf_1k.htm#09
Offline p3eps
« Reply #34 on: 05 April 2010, 18:28 »
There is an easy fix for the beeping... change the instrument panel to Europe instead of UK - and you can set the speedo to MPH and not have to worry about the US style seatbelt / key in ignition warning.
I turned off the seatbelt warning anyway, as it annoys me that my passenger seat beeps when I have a bag sitting on it!
Offline tezyuk
« Reply #35 on: 05 April 2010, 19:20 »
good find p3eps thanks ill go change mine now...
Offline sundaydriver
« Reply #36 on: 06 April 2010, 15:38 »
If you change it to EUROPE (germany etc) it will give you a larger problem. The mileage will be displayed in kilometers instead of miles!
For me i'd rather have the large MPH display option and i can live with the bongs (just put my seatbelt on and dont leave the keys in the ignition)
2012 Golf R, APR STAGE 2+, BCS power valve TB exhaust, loba HPFP, evoms intake, Rising blue, 19" Talladegas -BMW M2
Offline tezyuk
« Reply #37 on: 06 April 2010, 17:25 »
ive put mine to europe no bong anymore and you can set the mileage back to miles in mfd
all sorted and happy just want the sweeping dials now but carnt be done with my vagcom
need newer version..
« Reply #38 on: 06 April 2010, 18:40 »
 I havn't got EUROPE in my settings (germany,rest of world and a few more) and also can't change between kilometers - miles in the MFD.
Did also read somewhere if you cant activate staging(dial sweep) with VCDS you need to ask your VW dealer to update your instrument FIRMWARE and then you should be able to activate it but if your dealer's as dumb as mine i wouldn't count on it! :wink:
Offline p3eps
« Reply #39 on: 06 April 2010, 18:42 »
It wasn't Europe on mine... it was Rest Of World.
I didn't notice it was in KM, but I'll check tomorrow!
