Author Topic: Sanding advice  (Read 1117 times)
Offline dom
  • Back in a Mk4
Sanding advice
« on: 18 March 2010, 17:33 »
Right guys, I know this has probably been covered before but I couldn't find it with a search.
My dad is repairing some damage to the rear bumper on his Honda Accord estate, so far he's scratches filled the scratches and sanded down the filler. He then applied a couple of coats of primer, and is planning on sanding that down and applying a couple more coats of primer. He is then going to sand that with 1200 W&D, then apply a few coats of paint etc. Should he sand the paint using a really fine W&D before appling lacquer? If so what grit?
To finish he'll sand the lacquer with 2000 grit W&D, use a cutting compound on it and buff it all up using a Lambswool Bonnet on an orbital sander.
Does that sound about right? Or has anyone got any other suggestions? It's only a small area on the corner of the bumper.
Cheers  :grin:
Dom
