Author Topic: Give it a bit more grunt  (Read 3080 times)
Offline Evoss
« on: 18 March 2010, 14:25 »
I have a 1.6 FSI and want to give it a bit more grunt from its silence at the moment.
I dont want to fork out for a new exhaust etc.. what else can I do to make the engine purr a little bit?
I wld aprechiate links to the bits and bobs ur talking about.
Thanks
Offline Egbutt Wash
Re: Give it a bit more grunt
« Reply #1 on: 18 March 2010, 16:37 »
These guys should be able to help...
http://www.microminiatures.com/
Currently digging a bunker.
Offline Jimp
« Reply #2 on: 18 March 2010, 16:47 »
You can get a stainless steel or just a smaller mild steel back box as the standard one on the mk5 is quite big and silences it a lot. Would be cheaper than a full system.
A K&N/Pipercross/ITG panel filter makes the noise that bit nicer. I have a Pipercross in the 1.4, bought it directly from the Pipercross website a few months ago.
Another handy trick is to take out the parcel shelf  :grin: Sounds stupid but I rarely have mine in because I have gutiar amps in the boot regularly. Whenever I put the parcel shelf back in the car gets a lot quieter. Sounds silly but hey, it's free  :wink: :grin:
Not low enough mk5
Not on the road enough mk3
Offline FamilyDub
« Reply #3 on: 18 March 2010, 16:53 »
Another handy trick is to take out the parcel shelf...  :grin:
^^^ I love the drive home from the dump, for this very reason!
no parcel shelf and lowered back seats, FTW!  :laugh:
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline Evoss
« Reply #4 on: 18 March 2010, 18:23 »
Who is better K&N or Pipercross?
Is an induction kit worth anything ?
Offline Evoss
« Reply #5 on: 18 March 2010, 23:29 »
Does the pannel filter make the car sound better>
Offline maxp
  • J reg 8v digi gti
« Reply #6 on: 19 March 2010, 00:32 »
Changing just the filter itself wont, no. Fit an induction kit (also cheap) will give it a slightly more grunty noise although the hp gains are hardly worth it (+1hp?) (plus this may invalidate an insurance claim, whereas the panel filter, unless you are the unluckiest person ever, wont).
Jimp may be right about the panel filter actually making an audible difference, as i dont know the mk5 layout, but the airbox where the panel filter sits is normally totally sealed.
« Last Edit: 19 March 2010, 00:37 by maxp »
Offline Omega
« Reply #7 on: 19 March 2010, 00:57 »
Panel filter will achieve no noise. You wont get a decent sound due to the engine.
Cheapest way would be to drill the panel filter and drill the exhaust
or remove the cat and silencer from the exhaust making a 'straight' pipe.
Personally i just wouldnt bother, i always cringe at low engine cars installing 'power' or 'noise' mods. You will need to declare it, shooting up the insurance. Get a nice sound system instead to cover all the noise  :wink:
Offline 2007GTI
« Reply #8 on: 19 March 2010, 07:14 »
I pretty sure TT will tell you K & N are sh!te, I would try pipercross.
Offline Jimp
« Reply #9 on: 19 March 2010, 09:37 »
All panel filters are sh!te if you over-oil them. I've had the Pipercross in for about 20k now with zero hassle. They are both basically the same so it's whichever website you like more to be honest  :grin:
The airbox on the 1.4 and 1.6 is completely sealed and located in the engine cover. When changing it the engine cover comes apart to give you access to it. You could drill the cover but you'd only get hot air from the engine. The way it is as stock has some heat resistance, though admittedly not a whole lot. There might be a little more noise if you fit a cold air feed into the air intake pipe but I can't be sure because I haven't done it.
Omega, drilling the panel filter? I hope you meant airbox  :lipsrsealed:
Not low enough mk5
