Author Topic: Simon's Mk2 16v trackday project  (Read 30259 times)
dubcheryl
Re: Simon's Mk2 16v trackday project
« Reply #10 on: 20 March 2010, 12:59 »
Thats a very pretty mk2, good luck with all the work :)
Offline s1monc
« Reply #11 on: 20 March 2010, 13:07 »
Wrong pic ! all bits removed now.
Offline s1monc
« Reply #12 on: 26 March 2010, 17:46 »
Poly bushes fitted & Wishbones seam welded :smiley:, just going to clean them up a bit more & give them a quick coat of black Hammerite. Replaced the driveshaft gaitors & got the driveshaft back on & removed a stubborn trackrod end with some heat !  Its all going a bit slowly at the moment.
Just on the look out for some secondhand coilovers but quality ones.
Simon.
Offline s1monc
« Reply #13 on: 16 May 2010, 22:32 »
Car is all back together now and attended a trackday at Lydden Hill this weekend, quite suprised how well balanced the car is,seems to give really good feedback. Got a few issues to sort as oil temps were upto 130 on the mfa ! coolant gauge was also indicating past 3/4. Oil surge problem aswell plus my brand new R888 o/s/f is now illegal ned some spare wheels. I won't bother with another trackday until  sort these issues but on the whole really pleased with the car.
Cheers Simon.
Offline Diamond Hell
  • Opinions я Us
« Reply #14 on: 16 May 2010, 22:57 »
Original radiator?
Get a new one in.
You may find it'll cure both issues.
20 year old rads don't do a lot of cooling under duress.
Offline s1monc
« Reply #15 on: 19 May 2010, 12:32 »
The rad does look like its seen better days but it doesn't leak prob just not very efficient like you say. Anyway i know what issues i need to sort before i take it on another trackday but as the wife has just spent £23k on a new car today i am a little short of money plus my M5 needs a few bits doing so the Golf will just have to sit in the garage for a few months before it gets any attention :sad:
Simon.
  • Opinions я Us
« Reply #16 on: 19 May 2010, 12:47 »
tsk.
Sort your priorities.  :tongue:   :grin:
Offline s1monc
« Reply #17 on: 01 June 2010, 11:56 »
Fitted  an oil catch tank and going to relocate the washer bottle to the rear but need a smaller washer bottle.
Simon.
VeeDubGTI16v
« Reply #18 on: 02 June 2010, 08:49 »
why not run the breather straight out the block into the catch tank? then theres no oily vapour going into the intake, you need to block off where it goes into the airbox and inlet though.
or are you one of those greenpeace types  :laugh:
loving the weld on the wishbones!
Offline s1monc
« Reply #19 on: 14 October 2012, 10:06 »
Not posted on here for a while !
The engine finally gave up last year on a trackday, the headgasket had started to leak causing the cooling system to pressureize and blow hoses and i spun off the track as the antifreeze was leaking over my rear tyres !! I had already bought a abf bottom end and ported head so bought myself an engine stand and  removed the old engine and built up the new one.
Bought myself a timing gun and gas analyser and set the engine up,runs perfect.
Did a couple of sessions at Lydden Hill 2 weeks ago and the new engine seems good,feels quite pokey compared to the old lump but i have got it booked in at Stealth Racing to see if they can squeeze some more power out of it with the WUR mod and will be interesting to see what power it is as its bits i've picked up along the way to build the engine on a budget e.g Hotgolf exh cam & lightened flywheel.
Simon.
