Author Topic: Problem  (Read 4380 times)
Offline Rhyso
Re: Problem
« Reply #20 on: 15 March 2010, 14:27 »
ok so will just order that pipe ie replacement part and get some replacement clips....the joys..cheers. do I hit ebay for the part number or direct with vw?
VW :afro:
Make sure as Matt says you quote the RHD part number for the ASZ engine as per the picture I posted
Offline jonesltd
  • MK7 R
Re: Problem
« Reply #21 on: 15 March 2010, 14:29 »
winner will call up now and see if they got any in. Am guesing it should be replaced pretty soon as performance is lost/power?
If you cant find it......Grind it
Offline northeast_gti-t
  • "1.8T AGU"
Re: Problem
« Reply #22 on: 15 March 2010, 14:29 »
and that is for me engine? well was 130bhp but now chipped. Wicked not bad price. So if I get a new one then it wont keep coming loose? as the pipe doesnt look damanged at all? Just wont stay in flippin place! rude! hehehe, does it come in any other colour apart from black as I wanna change my pipe colours anyays
only colour is black unless you replace it with an SFS Performance hose but they are over £100....
Get some new clips and o-rings whilst ordering the pipe  :smiley:
does look good tho  :wink: :cool:
2000 Mkiv GTi 1.8T AGU
Offline jonesltd
  • MK7 R
Re: Problem
« Reply #23 on: 15 March 2010, 14:30 »
can i get it from anywhere like gsf? or those types of things got to be from vw
  • "1.8T AGU"
Re: Problem
« Reply #24 on: 15 March 2010, 14:33 »
if your fitting the oem part then i would replace it with a genuine vag part tbh may be a tad more expensive but you pays for what you get another alternative is to give trade parts specialists a call genuine vag parts but trade prices  :wink: will probs be £5 cheaper than vw and can get the part quicker :afro:
Offline Rhyso
Re: Problem
« Reply #25 on: 15 March 2010, 14:38 »
yep - basically venting all the boost to atmosphere instead of producing power
VW or Trade Part Specialists only
Its ok but the fitment isn't 100% as I noticed it rubs on the alternator  :sad: So i've had to cable tie it  :lipsrsealed:
Offline jonesltd
  • MK7 R
Re: Problem
« Reply #26 on: 15 March 2010, 14:40 »
48.90 from vw and 61pence for clips as it comes with o-rings. So will ring around anyway as they cant get the part till friday
Offline jonesltd
  • MK7 R
Re: Problem
« Reply #27 on: 16 March 2010, 15:23 »
is it easy to replace it? just lookin at it now and cannot figure out how to get the pipe off at the bottom ie pointing towards the lights etc the other part has already come off so thats simple
Offline Rhyso
Re: Problem
« Reply #28 on: 16 March 2010, 15:42 »
it uses the same clip as near the top but its much easier to remove the front bumper
Offline jonesltd
  • MK7 R
Re: Problem
« Reply #29 on: 16 March 2010, 16:01 »
ok I ended up taking the entire pipe out which goes into the well of the car and now tried to take it off the circle o ring thing off and the tools I have are for lighter work ie to take the MAF off so buggered at the min althou I have it in my hand
