Author Topic: Wining noise when reversing is it my brakes sticking !!!!!!!  (Read 2561 times)
Offline VWstevo
  • I feel The Need or Speed
Hey again,
Ok, when reversing my car especially when wheel turned hard left or right there is a loud wining noise as if something is rubbing on the brakes, i did have a stuck caliper the other week but i replaced this from another gti. Could  it be the caliper or could the handbrake be sticking. Any ideas ppl. Thanks again.
Steve.
« Last Edit: 12 March 2010, 20:24 by VWstevo »
Offline tonysmallwood
Re: Wining noise when reversing!!!!!!!
« Reply #1 on: 12 March 2010, 19:44 »
what car mate if its an 8v sounds like the gearbox i could be wrong tho but i know they known for it
Suspected scammer - account locked please do not buy from this user.
Offline VWstevo
« Reply #2 on: 12 March 2010, 19:47 »
Hi Tony had a new gearbox fitted 4 months ago it does do it all the time just every now and then. I sounds like it's coming from the back of the car and not the gearbox. And yeh it's a 8v buddy.
Offline Deano2711
  • 1992 VR6
Mine does the same Mate. Does it only happen now and then and not all the time??   I was told it was my pads worn unevenly. I looked at them and they had plenty of life left and will change them soon.      Cheers      Deano
Offline VWstevo
Hi Deano
Yeh mine does the same, also got fairly new pads on the back so not sure what's going on dude, does my head in, especially when ppl turn to look at the awful noise lol.
Offline Deano2711
  • 1992 VR6
Hi Deano
Yeah know what you mean Mate. But forget them it's not damaging your car or them. I keep checking my discs just in case but seen nothing untoward yet.
Offline VWstevo
Hi Deano
I fit new rear disc and pads not so long ago. It's only just started to do it a few weeks ago and it's on and off as i said. Just don't like these niggly things I've spent a lot on my car over the past few months getting it back to it's original glory. he he.
Offline bmw156
could be loads of things lol.
power steering if on full lock? check the belt,
rear pads, as mentioned.
rear disks warped?
my choice would be gearbox
Offline Deano2711
  • 1992 VR6
rear disks warped?
Don't think mine is power steering belt as mine only does it when reversing in a straight line. Also the noise is defo coming from the rear axle area. So I would go for the pads or maybe discs so this will be my next job but will wait a bit to get some more wear as mine is not that bad. Usually only does it in one place so I can put up with it a while longer yet.
Offline FlySpeck
dodgy wheel bearing - whining while running backwards?
I have never heard brakes "whine" - but maybe we are using different terminology of sound. Mine only ever "grind" like dragging metal along tarmac - or "squeal" like rubber soles on a polished floor -  if u know what i mean mate.
Whining I would liken to the sound of a washing machine on low spin, like the noise reverse gear makes cos theres no synchromesh on reverse. like a mmmmmmmmmmmmmmmm noise? lol
