Author Topic: mk3 lost key helpppppppppp  (Read 1409 times)
Offline lewisdale
« on: 10 March 2010, 19:16 »
hi guys just bough a mk3 golf gti 8v off a mate after it sat on his drive for a year because he lost the keys, ive replaced the ignition lock but the standar immobilser is kicking in, is there anyway to bypass this without spending a fortune on reprogramming?
what circuit does it cut out? was hoping maybe it was something silly like the fuel pump??
also if i was to replace transponder and ignition for a matching key would it work or would i need to replace ecu aswell?
thanks
Offline Matty-MK3
  • Automatic boats FTW.
Re: mk3 lost key helpppppppppp
« Reply #1 on: 10 March 2010, 19:19 »
Best bet would be to take some lube into a dealers or specialist and get them to code it AKAIK. :(
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Offline lewisdale
« Reply #2 on: 10 March 2010, 21:39 »
lol not going down that route
VW BUSH
« Reply #3 on: 10 March 2010, 22:03 »
Compatible Key ECU and Imob from breakers, maybe it will work? defo a lot of arsing around.
i am with the lube at least its painless  :grin:
Offline Adam
« Reply #4 on: 10 March 2010, 22:04 »
Go to scrappies and get an ECU and key and you should be good.
Down Hill From Here.
« Reply #5 on: 11 March 2010, 10:13 »
need to get a matched ecu, transponder box and key and you'll be alright. just be aware, there are 3 different engine managment setups available for the mk3 8v, so make sure you get the right ecu!
alternatively if you get a matched transponder box and key, you can match these to your ecu with vag-com.
