Author Topic: steering wheel swop advice pls  (Read 7894 times)
Offline devolute
  • Mk3 1.8 SE '96
Re: steering wheel swop advice pls
« Reply #10 on: 10 March 2010, 22:53 »
I've recently swapped my steering wheel for another one (still with an airbag).  Now though, the airbag light stays on.
How would I go about getting rid of that pesky light without an airbag going of in my face?
« Reply #11 on: 10 March 2010, 23:38 »
You will need someone with vagcom to reset it.
Offline devolute
  • Mk3 1.8 SE '96
« Reply #12 on: 11 March 2010, 18:41 »
I can get a VAGCOM on eBay pretty cheap. Is it an easy case to reset it this way, or am i likely to really muck things up?
Offline julesdub
« Reply #13 on: 11 March 2010, 19:48 »
hi
got my 24mm socket and treated mysef to (small,cheap 1/2 inch) socket set today  :grin:
question about the horn - is that all obvious?
and VAGCOM - see you can get on ebay for about tenner as devolute says - worth picking up or are they CR*%?
 :shocked:
cheers
Offline zdebx
« Reply #14 on: 12 March 2010, 08:12 »
hi
 :shocked:
cheers
Yeah, horn is easy. You will see it yourself, when you get there :)
Don't know about VAGCOM though  :lipsrsealed:
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
« Reply #15 on: 12 March 2010, 08:53 »
If you leave the battery disconnected and only connec it when you have all finshed you should not need vagcom.
Offline julesdub
Re: urgent steering wheel swop advice pls
« Reply #16 on: 14 March 2010, 17:12 »
hi guys
am in the middle of this job and there is a wire and plug at back of steering wheel i cannot diconnect. air bag is offf and steering wheel too but it is still held on by this plastic plug wire thing.  have tried to get in to behind wheel but think i have wrecked the steering surround  :undecided:
how do i get this plastic connector off and what is it?
ta
Offline patty
« Reply #17 on: 14 March 2010, 19:00 »
hi guys
ta
sounds like the wire comeing out from the slip ring(mine has a yellow connector block on the end)
it should unclip, mine was a little stiff ,but a good tug whilst holding the release bits on the other end of the connector and it came undone.
try that mate...might be it ?????
pat.
1996 black 5 dr 2.0 gti 16v
