Author Topic: brakes again sorry  (Read 3889 times)
Offline Rhyso
Re: brakes again sorry
« Reply #10 on: 08 March 2010, 12:45 »
Are the audi ones bigger then the standard golf ones where do i get rear calipers from
Audi brakes are 312mm don't know about rears but as everyone says it's only for show nothing to do with braking
It will help but the difference is not as significant as upgrading the fronts simply because the fronts do 70-80% of the braking
Offline vwprime
« Reply #11 on: 08 March 2010, 13:29 »
Justs to let you know (if you didn't already) the calapers are exactly the same along with the pads for the 312mm discs!Its the carriars that are diffarant. If you say your need new calipers any mk4 GTI 1.8t can be a good doner. Dosn't have to be TT, Anniversary, etc. The carriars some time come up on ebay but i coulden't find a link this time around to show you. This might save you a few quid mate  :smiley:.
« Last Edit: 08 March 2010, 13:30 by vwprime »
TRANSFORM, & ROLL OUT!
Offline mattGTI20
  • mattGTI20
« Reply #12 on: 08 March 2010, 16:57 »
yeh cheers all i need is the standard golf rear calipers i think the carriers are fine and then i just want discs and pads for the back, i just think that vw will be so expensive and didnt no where else to go cheers for looking anyway though.
Offline Devilz
  • Cruisin is not a crime
« Reply #13 on: 08 March 2010, 18:35 »
what about front, are audi tt disc and pads straight fit with mk4 calipers/carriers or do they need different set??
Offline richw911
Offline Devilz
« Reply #15 on: 08 March 2010, 20:17 »
so I need carriers as well, do you got part number for that rich??
Offline richw911
« Reply #16 on: 08 March 2010, 20:55 »
You need 312mm carriers - 2 of 1J0615125A and 312mm discs.
Pads are the same fore 288mm and 312mm  :nerd:
Offline Devilz
« Reply #17 on: 08 March 2010, 20:57 »
thats good, so i should only get disc and carriers to upgrade to 312mm  :rolleyes:
Offline richw911
« Reply #18 on: 08 March 2010, 20:58 »
Indeed i would fit new pads also  :smiley:
Offline Devilz
« Reply #19 on: 09 March 2010, 11:59 »
Carriers part number 1J0 615 125 A £108.13 each. Total comes £216.26, it's expensive  :shocked:
