Author Topic: Would a split breather / turbo pipe cause MPG to reduce??  (Read 9040 times)
Offline asif
Re: Would a split breather / turbo pipe cause MPG to reduce??
« Reply #10 on: 10 March 2010, 13:00 »
Is there a "how to guide" for how to checks your pipes are leaking?
What I mean is like a diagram/pic of the engine telling you which pipes to check for leaks, as i'm sure there are a few pipes that can leak right?
i know a common one is the one on the EGR but where are the other pipes and where do they end up etc.
Apologies if i'm asking a really dumb question i'm really not mechanically techy at all.
MK7 GT Bluemotion Tech TDi 150
Offline Rhyso
« Reply #11 on: 10 March 2010, 13:06 »
http://www.golfgtiforum.co.uk/index.php?topic=146077.0
I posted up some pics and an idea of where to look for leaks etc
Have the engine running and someone operating the accerlator to rev the car upto about 2500rpm
You then place your hand near all the joints and along the pipes, checking for any air escaping and listening out for any whistling
Otherwise you'd need a boost leak tester but the above should help for the home DIY'er
Offline asif
« Reply #12 on: 10 March 2010, 13:14 »
Cheers Rhyso your a top bloke  :wink:
Offline asif
« Reply #13 on: 10 March 2010, 13:30 »
After reading that other post Rhyso just sent me, is it me or are both the threads asking/talking about the same thing and getting replies to both?
Offline Rhyso
« Reply #14 on: 10 March 2010, 13:48 »
you're right
Offline asif
« Reply #15 on: 10 March 2010, 13:51 »
Thought I was going crazy or bog eyed :grin:
