Author Topic: [RESOLVED] Creaking from rear coilovers?  (Read 3026 times)
billabong
« on: 03 March 2010, 20:26 »
Hi Guys,
I fitted my coilovers the other week. Everything seems to be fine apart from I get a creaking on the back 2 shocks.
Due to how sound seems to travel through the springs and the body of the car, I cant seem to find which part is causing the creaking noise.
Anyone got any ideas??
Ta
Will
« Last Edit: 03 March 2010, 22:21 by billabong »
Offline Khare
  • The bear that khares
Re: Creaking from rear coilovers?
« Reply #1 on: 03 March 2010, 20:29 »
its the black plate separating the main and the helper spring. Spray some WD40 and it shall be gone, will be back soon though, I had to respray every so often.
Offline Adam
« Reply #2 on: 03 March 2010, 20:30 »
+1 Mine were the same
What make were the coilovers?
Down Hill From Here.
Offline Khare
« Reply #3 on: 03 March 2010, 20:34 »
mine were hottuning.
Offline Adam
« Reply #4 on: 03 March 2010, 20:38 »
dito, I'm going to guess billabong is using the same or a cheap set?
Offline VWstevo
  • I feel The Need or Speed
« Reply #5 on: 03 March 2010, 20:44 »
Hi I fitted new rear shockers etc and since fitting them when i seem to brake or slow down mine make a squeaking noise and it drives me mad, wot can it be lol.
Offline Khare
« Reply #6 on: 03 March 2010, 20:46 »
could be top mounts also
Offline VWstevo
« Reply #7 on: 03 March 2010, 20:49 »
changed them matey and all the washers springs everything new what you would need for the rear shockers. Do you reckon sum WD40 n them mite hep.
Offline Khare
« Reply #8 on: 03 March 2010, 20:55 »
give the entire spring and shock a spray in WD40 then, seek if it helps.
« Reply #9 on: 03 March 2010, 21:01 »
Mine creaked, I used spray grease but wd40 should do the same trick.
