Author Topic: knock sensor  (Read 2147 times)
Offline iamwills
Re: knock sensor
« Reply #10 on: 28 February 2010, 11:25 »
ok so if timing sliped would that evect the knock sensor. or would a faulty knock sensor evect the timing , , wot im trying to say is that if the knoock sensor was playing up would that cause the timing to go out  and bring up the knock sensor , thanks again for all your help
Offline leegt5
Re: knock sensor
« Reply #11 on: 28 February 2010, 13:02 »
If the knock sensor was faulty it would read the timing incorrectly. However before you replace the knock sensor get the timing checked to make sure everything is where it should be. If it is then think about replacing the knock sensor.
Offline iamwills
Re: knock sensor
« Reply #12 on: 28 February 2010, 17:10 »
ok if i get the timing fixed, and it is the knock sensor will it keep throwing the timing out.
Offline FlySpeck
Re: knock sensor
« Reply #13 on: 28 February 2010, 17:27 »
if you got a code for the knock sensor, then the ecu is reporting it faulty, non responding or reading way out of whack. That means usually that the sensor itself is faulty, especially if not in conjunction with other codes.
OBD is a diagnostic system to identify sensor or control faults, not to inform of running conditions in general but as a system check of all sensors.
The noise you describe may be getting picked up by a knock sensor, but that wouldnt trigger a knock sensor code, instead something like timing retardation figures in the ecu would change, the cel might come on for max timing retard reached but the code would be like "reading out of range", if its a fooked sensor of any kind you get "implausible signal or open circuit" type of codes (im generalising of course)
A knock sensor is a wee microphone and so can go open circuit, triggering a knock sensor error code. You should be able to check it with a basic ohm meter on low range - say up to 100 ohms. Any reading means its ok, its a little voice-coil so goes open circuit if faulty. This mic picks up sounds and that signal is fed thru a filter in the ecu analog inputs to look for the sounds of pinking or pre-ignition which have a specific range of frequencies that are known to be emitted from the cylinders when knock occurs. If knock is detected, the timing is retarded until it stops, or hits the limit. Then it goes to limp mode if the limit is reached, I know scoobs can pick up noise from a new oilfilter not filled yet on first start and trigger timing retard, possible wi the golf i suppose for other noises but unlikely as they are pretty accurate when working.
If the KS is showing as missing or faulty to your ecu, it will pull the timing back and go into limp mode as it cannot determine correct max timing advance any more.
Hope this helps mate ;)
« Last Edit: 28 February 2010, 17:29 by FlySpeck »
Offline iamwills
Re: knock sensor
« Reply #14 on: 28 February 2010, 22:47 »
ok so if i start with a new knock sensor, if working right it will rev over 5000rpm thanks 4 all your help mate, as such a old car now im sure all the sensors will probly need replacing, thanks again
Offline iamwills
Re: knock sensor
« Reply #15 on: 28 February 2010, 22:50 »
the first sensor is directly infront of engine on lower blok. ware is the other ,,
Offline FlySpeck
Re: knock sensor
« Reply #16 on: 01 March 2010, 07:53 »
one is behind the alternator. the other is above the oil filter housing mate afaik
remember they have to be torqued down to the block at 25nm or they wont work properly...
« Last Edit: 01 March 2010, 07:56 by FlySpeck »
Offline iamwills
Re: knock sensor
« Reply #17 on: 01 March 2010, 13:48 »
ok thats great just one more question. a mecanic just told me ther is only one knock sensor on a gti 8 v. 2.0l . and ther is  2 on the vr6 is this right ,
Offline axewielder
  • 95 dragon 8v
Re: knock sensor
« Reply #18 on: 01 March 2010, 13:54 »
yeh thats right, if its an 8v then the knock sensor is on the front of the block
Offline iamwills
Re: knock sensor
« Reply #19 on: 01 March 2010, 14:28 »
ok thanks a lot , will post when i finaly get it over 5000 rpm .thanks again mate.
