Author Topic: 5 studding.  (Read 1445 times)
Offline sep
5 studding.
« on: 24 February 2010, 18:59 »
i have a full mk3 gti and was thinking if i broke it could i use the hubs to 5 stud my mk2??
if so what do i need to do etc?? its an 1.6 8v ryder and a gti 16v mk3
Offline Diamond Hell
  • Opinions я Us
Re: 5 studding.
« Reply #1 on: 24 February 2010, 23:57 »
What's the matter with the 16V engine?!
If you break it that car has rather more interesting bits than bloody five-stud hubs on it!!
Re: 5 studding.
« Reply #2 on: 25 February 2010, 11:59 »
only if you also fit the 5 stud wishbones, 4/5 stud bearing carriers have the ball joints offset differently so it throws out the castor. you can however press out the hub from 5 stud bearing carriers and press into 4 stud bearing carriers, but you have to re-drill the 4 stud discs to 5 and fit MK3 GTI outer cv joints.
As DH says though, make sure you at least use the engine ;)
Offline sep
Re: 5 studding.
« Reply #3 on: 25 February 2010, 17:43 »
lol being honest the car is clean, engine is sound too.. baught it as a mot fail, failed on front bottom arms, arb bushes and brake pipes. also had a dinted wing. thinking of stripping it as cant be arsed to fix it. thats all. rather spend my time on my mk2
Offline sep
Re: 5 studding.
« Reply #4 on: 25 February 2010, 17:47 »
just re reading your post, i just need to change the bottom arms and outer cv's? i have 2 new bottom arms here. what about the rears???
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: 5 studding.
« Reply #5 on: 25 February 2010, 20:08 »
rears are a straight swap. Up front you need to change the anti roll bar, wishbones, cvs, arbs as posted earlier.
  • Opinions я Us
Re: 5 studding.
« Reply #6 on: 25 February 2010, 21:47 »
Drop the whole front subframe off the G3, re-bush and bolt up under your G2.
Hybrid vigor FTW.
Offline Agreeable Slick
  • Unit
Re: 5 studding.
« Reply #7 on: 25 February 2010, 23:20 »
Plenty of topics on this.
try this. http://www.golfgtiforum.co.uk/index.php?action=search
