Author Topic: FAO anyone whos fitted heated seat loom  (Read 882 times)
kells
« on: 24 February 2010, 14:36 »
just put mine in and a couple of Q's as i cant test seen as my interiort isnt in yet
i found the conector plugs behind the dash which you plug the loom into, on the blue one and green one, its possible to plug it into 2 slots on the smae multiplug (of each colour)  so im guessing i can plug into either of these aslong as its on the same colour block?
i know the blue is illumination and green is ignition live, my switch is not illuminating, although this could be down to the loom not been plugged into the relays and seats ?
Offline zdebx
Re: FAO anyone whos fitted heated seat loom
« Reply #1 on: 24 February 2010, 17:57 »
If it's the same colour block, you can plug it wherever you want. It will work anyway.
Although, not sure about the switch illumination. Try connecting everything, and then see if it works.
Have you connected the brown plug?
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
adamrob69
« Reply #2 on: 24 February 2010, 18:11 »
without looking at the wiring diagram; i wouldnt worry to much untill you get the whole circuit connected up
kells
« Reply #3 on: 25 February 2010, 08:49 »
all plugs are in yes zdebx
adamrob69 thinking same, seats are set to be ready on Saturday :-), although im usinhg a uprated heat pads in my seats, with their own loom, although this has same amount of wires as the VAG loom so i home it will all work!
