Author Topic: Vento front-end on Golf - Universal fitting?  (Read 3482 times)
Offline buzzkip
« on: 22 February 2010, 16:51 »
Hi all,
I was wondering whether or not the fitting for the Vento hood, grill and lights would fit straight onto a Golf. More importantly, would the light/power connectors be the same?
Thanks!
Changed username from "iAMarshall".
Offline shepgti
Re: Vento front-end on Golf - Universal fitting?
« Reply #1 on: 22 February 2010, 17:09 »
more importantly has this question been asked 1,230,203 times? :undecided:
Offline Jimp
« Reply #2 on: 22 February 2010, 17:24 »
Yes, though the light connectors will be different if your Golf had the two chamber lights. The connectors from the Vento should plug right in though  :wink:
Not low enough mk5
Not on the road enough mk3
Offline Mikester
  • Civic Type R
« Reply #3 on: 22 February 2010, 17:30 »
It wont fit at all i'm afraid without serious welding.
Offline VR6-Joe
« Reply #4 on: 22 February 2010, 18:47 »
And that's just to get the lights to fit onto the slam panel! Don't be forgetting the custom fabrication to the wings and bonnet, aswell as the technical wiring harness adapters, and the fact the lights won't sit right with the Golf bumper. I have a Vento bumper in my shed if you want it?
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Mikester
  • Civic Type R
« Reply #5 on: 22 February 2010, 18:50 »
Then you have to fit the grille!
Offline VR6-Joe
« Reply #6 on: 22 February 2010, 18:59 »
F**k me, that was a nightmare. Those clips just don't like to push in, unless you modify the slam panel a little, with an angle grinder, or hacksaw. Did you have any probs with yours Mike?
Offline Mikester
  • Civic Type R
« Reply #7 on: 22 February 2010, 19:02 »
The vento front was the reason i sold it.
Offline VR6-Joe
« Reply #8 on: 22 February 2010, 19:04 »
I changed mine back but was a lot of work. New slam panel, new bonnet, new wings, new wiring loom all the way back to the fusebox, new grill, new headlights, new bumper, I'd never do it again personally.
Offline Khare
  • The bear that khares
« Reply #9 on: 22 February 2010, 19:05 »
Don't listen to them jokers  :rolleyes:
You need to cut a few parts of the slam panel away to fit the grill and headlights, and you need the vento front crossmember and subframe.
The lights are as shep said, if they are single chamber, straight in, if not then you need to re-wire all the headlight look with the vento unit and it is advisable to stick relays on it too.
 :grin:
You need vento bonnet, headlights and grill.
But what shep said about the lights is true tough  :smiley:
