Author Topic: Clearing Washer Jets  (Read 3147 times)
Offline rsjm2002
« on: 20 February 2010, 15:57 »
Any help much appreciated.
How the **** do you clear the jets on the mk 5 golf? The passenger side one has suddenyl reduced to a thin dribble rather than a big mist/spray.
There's a screw next to it, but don't want to do anything in case it's the wrong thing!!
Thanks
richard
Offline DanoGTI
Re: Clearing Washer Jets
« Reply #1 on: 20 February 2010, 19:01 »
screw just changes the direction.....
I gave up and spent £12 @ VW on some new ones (different design from my 05 - use a torx adjuster instead of a screw)
imho, by FAR the weakest point of the car's design.
However, you can take em off and soak in hot water - this does the trick for a while anyway.
HTH
Dan
DA Productions
The fine art of diplomacy is telling somebody to "fcuk off" in such a way that they actually look forward to the journey....
Offline mb
« Reply #2 on: 20 February 2010, 20:07 »
One of my jets reduced to a dribble.  Tried blowing it out and soaking it but no joy.  Ended up getting it replaced under warranty.
Offline rsjm2002
« Reply #3 on: 21 February 2010, 12:48 »
And how do you remove the jets? (dumb question but looked and prodded and not found a way yet)
Offline maxie
« Reply #4 on: 21 February 2010, 13:39 »
my back ones blocked also.  :(
Offline mb
« Reply #5 on: 21 February 2010, 15:12 »
They are clipped into the underside of the bonnet and just pull out.  Then you just need to disconnect the water pipe.
Remove the black plastic cover and the washer jet just pulls off with a pair of pliers.  Remember to point the jet away from the high level brake light when refitting.
Offline rsjm2002
« Reply #6 on: 21 February 2010, 18:13 »
Thanx to all - I got the jet off. Water coming through to the pipe, washed and poked about with the jet but still nothing SO it looks like it might be the new (and improved) jets from veedub.
Offline Gene Hunt.
« Reply #7 on: 22 February 2010, 07:13 »
I've found if you put a couple of steri tablets into some boiling water & add this to the washer bottle this helps.When i got my GTI the washer bottle had a terrible mouldy smell when i went to fill it for the first time.Been adding the tablets every now & again & no problem ever since.
Candy White ED35.
« Reply #8 on: 22 February 2010, 09:16 »
Try blowing them through with a air line.
Offline Yorkishire
« Reply #9 on: 25 February 2010, 13:35 »
Sounds daft but if you live in hard water area then you get a build up of 'scale' similar to the stuff you get in irons.  Soaking it in boiling water helps but in the past, when I lived down south, I used the iron cleaning stuff to get rid of the scale.
2006 GTI T 200PS | Steel Grey| 3 door | Manual | 18" Monza II's | Leather |DVD | MFD2 Satnav | Centre Armrest | Ipod Prep | Highline MFD | Winter Pack
