Author Topic: front engine mount  (Read 1436 times)
Offline ianmaxtec
front engine mount
« on: 16 February 2010, 22:13 »
Changed the engine mounts in the car about 6 mts ago, and the front mount is in bits already !
Can anybody suggest where I might get a new "stronger" mount? I found some on ebay, but £140 is way beyond what I want to pay, at the same time I dont want to buy something for £20 thats not going to last
Offline LazyLunatic
  • MK3 20VT Project
Re: front engine mount
« Reply #1 on: 16 February 2010, 22:20 »
you can get a solid mount. there is a guy thats makes his own and they re very good quality and much cheaper than vibratechnics and the like.
http://cgi.ebay.co.uk/vw-golf-mk2-solid-front-engine-mount-8v-16v-gti_W0QQitemZ220556631518QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item335a331dde#ht_500wt_1182
^^ its something like that.
i think the guy that makes them is on clubgti.com
i got the mk3 version on my and cant fault it! although make sure you use loctite on the mount bolts and remember to check the other bolts every now and then :)
Offline ianmaxtec
« Reply #2 on: 16 February 2010, 23:23 »
With the solid mounts do you not find the ride very harsh ? will this not put added pressure on the sub frame ?
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #3 on: 17 February 2010, 08:42 »
TRY A 1.3 FRONT MOUNT, ITS SOLID CONDED RUBBER..
just looked up and i wrote that in caps but my hands are too cold to do it again.. give me a shout if you're interested!
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline ianmaxtec
« Reply #4 on: 17 February 2010, 09:22 »
will the 1.3 mount fit a 86 gti without any mods ? sounds like a good idea, any pics ?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #5 on: 17 February 2010, 10:03 »
i dont know about the mk2, but the mk3 subframe has bushes in and its fine, no strain on the car. it also makes a hell of difference too. the engine doesnt hardly move with a solid mount! when i let off the throttle, and boost goes back down, its much smoother as i dont get the engine jerking back and forth.
Offline ianmaxtec
« Reply #6 on: 17 February 2010, 14:09 »
as far as I am aware there are no bushes on the sub frame on the mk2. I did mention it to a friend who has a mk2 and he reckons the solid mount would tear the sub frame in time !
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #7 on: 17 February 2010, 14:49 »
no bushes on the subframe, but there are bushes on the front cross member where the engine mount is located.
Offline maplesyrup
« Reply #8 on: 17 February 2010, 21:48 »
I fitted a solid front mount 8 months ago and have had no problems.
The cross member is bushed so seems to take the extra strain ok.
"when the going gets weird the weird turn pro"
