Author Topic: GT TDI 150 No POwer  (Read 18000 times)
Offline Steve_PD
Re: GT TDI 150 No POwer
« Reply #20 on: 15 February 2010, 18:45 »
you've most defiantly gone into limp mode. mine used to do when driving down the motorway at 65-70 then the slightest touch of the throttle the turbo would cut out.
used some turbo cleaner and touch wood it hasnt done it since  :lipsrsealed:
Offline th3musicmak3r
« Reply #21 on: 15 February 2010, 22:12 »
how easy is it and  how much is it to do the turbo cleaning kit? price etc
« Reply #22 on: 19 February 2010, 13:08 »
Just used a VAG COM on the car came back with 17965. What is this? e.g. what is it relating to and how do i resolve the issue. e.g. whats parts are effected?
Offline Rhyso
« Reply #24 on: 19 February 2010, 13:17 »
Cool thanks. Mine doesnt seem to have gone into limp mode since it has happened just wondering wither it was having a dickyfit. Shoulod i just clear the code and see if it happens again?
« Reply #25 on: 25 February 2010, 16:33 »
well drop the car in the garage today so hopefully i should have a better idea as top what has gone wrong. fingers crossed nothing expensive
« Reply #26 on: 25 February 2010, 19:31 »
came back with the following using autodata v3.18. Turbo Charger wastegate regulating valve which is at fault
Offline Adam
« Reply #27 on: 25 February 2010, 19:32 »
N75 valve,
Down Hill From Here.
« Reply #28 on: 25 February 2010, 19:36 »
how much is one of those?
Offline Rhyso
« Reply #29 on: 25 February 2010, 19:38 »
£30 or thereabouts and 2 minutes to change
