Author Topic: mk2 problem  (Read 2349 times)
Offline vwgti16v
Re: mk2 problem
« Reply #10 on: 15 February 2010, 18:50 »
thats great thanks for the help i will give it ago hopfully it will solve the problem.
Offline Cory
Re: mk2 problem
« Reply #11 on: 15 February 2010, 22:42 »
dont ur revs usually drop when you engange the clutch anyways? or am i bein stupid? also, i still sometimes think mine sounds like its about to stall, but never actually does.   possibly a warming up problme + a maunal choke?   my 89 has a manual choke =)
Re: mk2 problem
« Reply #12 on: 16 February 2010, 10:58 »
the digi should catch the revs at 900ish without an issue, if it drops lower than that and stalls at times, then usually the issue is the idle switch, wiring or perhaps the isv.
i know this becasue mine went thru a phase of snapping the tb wires once a month, in the end i added an extra inch to the wiring and that sorted it
