Author Topic: What Size Is This? (MK3 Tuned ABF Engine)  (Read 26490 times)
Offline Ess_Three
Re: What Size Is This? (MK3 Tuned ABF Engine)
« Reply #30 on: 20 March 2011, 11:13 »
vr turboed? or with a blower?
and a few other bits
None of the above.
2.0 16v NA Lehmann engines, re-worked standard heads (probably bigger valves), forged internals, revving to 8500+ RPM, CR of 13:1 I'd guess, solid lifters and 300+ degree duration cams with I'd guess around 13.5mm lift, and throttle bodies.
Nothing you can't do yourself...if you have the money, and want ro rebuild it twice a year.
I have the VW Motorsport Kit Car Cataloge somewhere....some tasty parts in there. Unobtainable, of course!
Lehmann will still build you one...it's the suspension and gearbox stuff you struggle for nowadays.
Wheels, brakes, dampers etc are all readily available...the Gemini gearboxes are not, same with the rear beams, front hubs etc.
EDIT:
Just checked the catalogue:
12.8:1 CR, 8000 RPM, 260BHP NA, with a catalyst, running Bosch Motronic and 48mm vertical pivot ITBs, 8 injectors, and a closed airbox.
90mm x 84mm bore/stroke.
Price listed FROM DM 250,000
« Last Edit: 20 March 2011, 11:24 by Ess_Three »
..but gaining motorcycles.
