Author Topic: Throttle body cleaning.  (Read 16847 times)
Offline jocarl11
« on: 11 February 2010, 19:00 »
Hi, I'm about to clean the throttle body on my car is there anything i need to do with the ecu once it's done like a reset? I've been readin around and some seem to say it requires a TBA (Throttle body alignment) of the ecu?
Offline FlySpeck
Re: Throttle body cleaning.
« Reply #1 on: 11 February 2010, 19:03 »
yeah. dont touch the tps (throttle position sensor) on the tb, leave it on when cleaning, just dont bang or drop it.
Take tha battery off, and when your done, hook it up and turn on the ignition, dont start it, there will be loads of whirring and clicking - when that stops, you can start the engine.
vag-com can force a tb alignment, if you have it.
Offline Ess_Three
« Reply #2 on: 11 February 2010, 21:03 »
TB alignment? On a Mk3 16v?
I don't think so...they are throttle cable, so don't need an 'alignment' as the 1.8Ts do.
It looks to be a 16v in the OPs sig.
You can re-code the TPS to the ECU...but shouldn't need to...certainly not after cleaning.
..but gaining motorcycles.
Offline christomk3gti
« Reply #3 on: 11 February 2010, 21:06 »
Ess - does this apply to the 8v aswell...???
As i really need to clean mine, and polish it with some nice metal polish from work.... :afro:
Black 8v GTI............. Whats a Waffle Valve?
Offline Deano2711
  • 1992 VR6
« Reply #4 on: 11 February 2010, 21:15 »
I took mine off, cleaned it up and then refitted with no problems whatsoever.
Offline Ess_Three
« Reply #5 on: 11 February 2010, 21:18 »
Not sure about SIMOS 8vs...but the early ones I seem to recall had a throttle cable.
16vs certainly do...along with early 2.8 VR6s and 2.9 VR6s.
When you hear polishing...it's not actually necessary to polish it up like a mirror...it's a poor term really.
You just need to remove any casting marks, clean up the air flow path etc.
Offline leigh_harty
  • Audi AGU
« Reply #6 on: 11 February 2010, 21:19 »
Same here, for a 16v.... i tell a lie i had the throttle reset thru vagcom
Dont lose your dinosaur!
Offline FlySpeck
« Reply #7 on: 11 February 2010, 21:20 »
whoops! soz lads, i am thinking of the fly-by-wire tb on the audi, doh!
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #8 on: 11 February 2010, 21:39 »
Likewise, the simple undoing of 4 bolts and and some elbow grease is all that is needed here.
Offline Khare
  • The bear that khares
« Reply #9 on: 11 February 2010, 22:02 »
all mk3s have cable TB, so no need to realign.
