Author Topic: Original VW Bluetooth thats not rSAP??  (Read 6142 times)
Offline jawson
Re: Original VW Bluetooth thats not rSAP??
« Reply #10 on: 11 February 2010, 09:07 »
I see the original position for mounting the control unit is under the passenger seat, but is there enough room to mount this unit behind a RCD510?
First it was going to be a Fiscon, then Mobridge and now I think finally I will get one of these - OEM mic and iPhone compatibility sounds perfect.
Offline danski
« Reply #11 on: 11 February 2010, 10:30 »
I`d say golfgti5 is the man to ask any questions of, I dont know for sure that voice dialling will work - I dont even have my car yet, never mind the kit - I`m just assuming.
Good bit cheaper than the Fiscon/MoBridge kits too, I just wanna know why we havent heard about it sooner  :huh:
Golf GTD, 2010, 3 Door, Deep Black Pearl, Leather, RCD510, Reversing Camera, 18" Vancouvers, Storage Pack, R LED Rears, More GTECHNIQ protection than I can shake a stick at....
Offline golfgti5
« Reply #12 on: 11 February 2010, 11:36 »
Voice dialling is no problem, just put 1 extra wire on the RNS510;
http://www.my-gti.com/1234/volkswagen-rns-510-microphone-connection-for-voice-control
GTI Mk7 DSG Candy White, 19" Santiagos, Discover Media, xenon, Executive Package, ACC, PDC, Park Assist, Alarm+......
Offline DDg
« Reply #13 on: 28 February 2010, 10:14 »
Is there any advantage going for a Fiscon when this unit seems to do it exactly the same (or does it?)?
Offline golfgti5
« Reply #14 on: 28 February 2010, 15:53 »
Fiscon is not original VW...............
Offline Ess_Three
« Reply #15 on: 28 February 2010, 16:46 »
So this is plug and play?
Remove the RCD/RNS, plug in, and code it..that's it?
No microphone wiring to run?
How's it work then if you don't have to run one?
..but gaining motorcycles.
Offline SteveP
« Reply #16 on: 28 February 2010, 16:59 »
Here is a very good guide for installing the OEM bluetooth - http://www.octavia-vrs.com/cms/content/integrated-bluetooth
It's a little more simple if you buy one of the full kits from ebay (as linked earlier in thread).
Offline p3asa
« Reply #17 on: 28 February 2010, 17:44 »
I only had a quick look at the installation link you linked to but it looks a whole lot of hassle compared to the fiscon or mobridge which are plug and play and all done within inside 5 minutes.
I suppose the big difference is that unit is housed beneath the seat rather than tucked away behind the head unit.
Offline SteveP
« Reply #18 on: 28 February 2010, 17:48 »
^^^ I agree the original install was a lot more work, but with the newer looms on the kits from ebay it no longer requires the extra wires to be connected and is plug and play (same style as the fiscon). You can also choose to mount the bluetooth module behind the headunit but it really not diffcult to put it in the OEM place under the seat  :smiley:
