Author Topic: cняis's orange mk2 VR6 - Dash out P.42  (Read 181949 times)
Offline cняis
Re: cняis's orange mk2 VR6 - Custom C.A.I. & new front end p31
« Reply #320 on: 09 November 2010, 23:05 »
looking really good Chris, hats off you going through that car meticulously! :afro:
not going to put the green stripe back on this grille then?
cheers, its coming together piece by piece, need to get the dash area sorted next what with missing screws and clocks which vibrate ocassionally. also need a new wing bracket (which the bumper slides over) as the NS one keeps popping out  :rolleyes:
ref the green stripe, the novelty wore off tbh, but we're clearing out a load of touch-up sticks at work so i might have a rummage through those  :wink:
then im thinking maybe black vinyl on the bonnet/roof?
« Reply #321 on: 10 November 2010, 10:04 »
To be honest I think it would not suit it.
Offline robz
« Reply #322 on: 10 November 2010, 11:00 »
agree with wayne, not keen on his trend!
Offline clipperjay
« Reply #323 on: 10 November 2010, 18:28 »
Chris try photoshoppin the VR badge and VW emblem in black or Orange it might look nicer on the black grill? Just a after though? But it is coming along nicely and
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #324 on: 10 November 2010, 22:36 »
100% better.  :cool:
That bit of chicken wire you were using as a grille was awful.
+1 much better. :wink:
Offline Sam
  • Sam I am
« Reply #325 on: 10 November 2010, 23:27 »
Right then, thats my next job. Cold Air intake, looks gooood!
Offline cняis
« Reply #326 on: 11 November 2010, 00:18 »
the only thing i'd change about it is where the pipe picks up from...
use the front of the fog housing only and not the projector shell, that way you could get away with a bigger bore pipe i.e probably 70mm rather than 50mm (you would need to double check the correct size though). you'd have to squish the flexi pipe into a rectangular shape to match the fog housing but im sure you could manage that  :grin:
Offline banterchicken
« Reply #327 on: 27 November 2010, 01:30 »
Was roaming around in my neighbour hood on google streetview, (used to live near ben)
*removed*
« Last Edit: 29 November 2010, 17:13 by banterchicken »
Offline monkeyalan
« Reply #328 on: 27 November 2010, 07:32 »
cut the bit out with his postcode dude , he'd be pi55ed off if his car got nicked.  :wink:
Offline Neo Badness
  • Feet are for pedals
« Reply #329 on: 27 November 2010, 11:46 »
+1
