Author Topic: Rough idle  (Read 18788 times)
Offline Mr_Orange
Re: Rough idle
« Reply #10 on: 12 February 2010, 18:45 »
- turns out my front lambda sensor was completely dead, no voltage coming out at all.
Got that replaced today and oh my what a difference, car seems to be running perfectly!
What was the pain $$$$$ ?
Build thread clicky
Offline radz
Re: Rough idle
« Reply #11 on: 12 February 2010, 18:55 »
Part itself cost around £60 for a bosch, but I didnt have time to do it myself >.<
So overall cost me £120 which still isnt too bad if it fixes the problem.
Offline Mr_Orange
Re: Rough idle
« Reply #12 on: 13 February 2010, 16:11 »
Just stripped off and cleaned out the vacuum systems under the inlet manifold.
It was full of gunge!  The suction jet pump, most of the pipework and the crankcase breather valve (puck thing) were thick with it.  No obvious pipe splits but some of the hoses had deteriorated quite badly inside.
With it all apart I noted down some useful numbers for the AUM:
Crankcase valve (puck)  034129101B
Suction Jet Pump  058133753B
PCV valve  035103245A
The "soft" pipes that have gone bad: 06A103247, 06A133784P, 06A133783AS, 06A133783H
Didn't sort the idle.....  I admit defeat and will be seeking further help.
« Last Edit: 18 February 2010, 19:20 by Mr_Orange »
Build thread clicky
Offline johnson6672
Re: Rough idle
« Reply #13 on: 13 February 2010, 16:16 »
Can you post some pics of what you cleaned?
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline Mr_Orange
Re: Rough idle
« Reply #14 on: 13 February 2010, 16:29 »
Removed and cleaned out this little lot:
This creamy gunge is what spilt out when I removed the pipework:
« Last Edit: 19 February 2010, 14:50 by Mr_Orange »
Build thread clicky
Offline T_J_G
Re: Rough idle
« Reply #15 on: 13 February 2010, 16:40 »
You need a catch can mate! :afro: Sod paying VW prices for all those pipes when they can be replaced with a fresh looking catch can install:
EDIT: What ones you got to replace mate?
Offline Mr_Orange
Re: Rough idle
« Reply #16 on: 13 February 2010, 16:43 »
The 3 soft (not solid plastic) ones will be coming back out.
Build thread clicky
Offline johnson6672
Re: Rough idle
« Reply #17 on: 13 February 2010, 16:47 »
Think i might have a look at that lot when i do my service.
Offline Mr_Orange
Re: Rough idle
« Reply #18 on: 13 February 2010, 16:52 »
Its rather fiddly and depending on age/mileage they will likely be very manky.  I spent 3 hours doing this today.  Cutting off the original hose clips, it took about 12 jubilee clips to put it all back together.  Would have been nice to find a great big split in something, but hey-ho....
Build thread clicky
