Author Topic: Cruise control VAGcom coding info wanted.  (Read 6280 times)
Offline topher
  • Administrator
  • fully functioning
Re: Cruise control VAGcom coding info wanted.
« Reply #10 on: 18 February 2010, 20:46 »
in 01 - Engine. Coding -> Long coding helper -> byte 06 - click the box to enable CC
The steering wheel coding is even easier - hover over the text box and it'll pop up a list of instructions like these http://wiki.ross-tech.com/index.php/VW_Golf_%281K%29_Steering_Wheel#Coding
Offline p3eps
« Reply #11 on: 09 March 2010, 21:14 »
It's a bit fiddly to remove the old stalk and for coding you need to activate it in controller for the steering wheel and engine  :smiley:
I've ordered a VagCom, so I'm up for having a go at this now.  When you say its a bit fiddly, how fiddly are we talking?!  Do you change over the whole stalk, or is it a case of fitting the control switches into the blank plate in the existing stalk?  Does it involve removing the steering column or anything like that?
Can anyone tell me if the MK6 stalk is the same as the MK5 one?  Since I'm going to have a VagCom, £50-60 for the stalk makes it a nice extra - but I probably wouldn't pay £150 for it as I rarely do motorway driving.
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline SteveP
« Reply #12 on: 09 March 2010, 21:17 »
^^^ It requires the whole stalk to be replaced, which needs the steering wheel and cowling to be removed.
Offline p3eps
« Reply #13 on: 09 March 2010, 21:51 »
Steering wheel removed  :shocked:
Perhaps I'll give it a miss.  I would have easily removed the plastic cowling, but I'm not up for taking off the steering wheel.  A
I'd end up with the airbag in my face  :laugh:
Offline SteveP
« Reply #14 on: 09 March 2010, 21:58 »
^^^ It's a lot easier than it sounds, the airbag is held on with two clips, just turn the wheel 90 degrees and get a flat screw driver and a small mirror (after disconnecting the battery) and push the clip over the brackets  :smiley:
Then the wheel is held in place with one multi point spline bolt (M12 IIRC).
Offline p3eps
« Reply #15 on: 09 March 2010, 22:00 »
And how easy is the plastic cowling to come off?  I'd just be dubious that my airbag wouldn't work properly after I'd dicked about with it!!  If there was a how to guide with piccy's, I might feel a bit more confident.
Offline SteveP
« Reply #16 on: 09 March 2010, 22:03 »
Not sure on the Mk6 cowling, with the Mk5 there was one screw under then it just unclipped on the sides, I will double check on my Mk6 and let you know  :smiley:
Offline p3eps
« Reply #17 on: 10 March 2010, 07:12 »
Nice one... cheers!  I'll have a look tonight and see if I can find a 'how to' guide.  Someone must have done one somewhere!!
Offline p3eps
« Reply #18 on: 10 March 2010, 20:32 »
I've found a MK4 fitting guide which looks awful complicated...
I'll keep looking for a MK6 one.  I wonder if Elsa tells you how to do it?
Offline p3eps
« Reply #19 on: 13 March 2010, 14:52 »
Can anyone confirm whether the MK6 uses the same Cruise Control stalk as the MK5?
I can buy an MK5 one no problem, but can't find anything listed as MK6.
Since its technically a MK5.5 - I would have thought it would be the same thing  :tongue:
