Author Topic: Taking off door handles  (Read 3003 times)
Re: Taking off door handles
« Reply #10 on: 21 January 2010, 19:45 »
Yes it works, did it on mine with no issues.
Offline robertb2700
« Reply #11 on: 21 January 2010, 19:47 »
Seems to be the overall view, just didn't wanna try it and stop it from locking  :huh:
Rogue trader - pm's disabled - robertb2700@live.co.uk
« Reply #12 on: 21 January 2010, 19:54 »
It won't, not sure why you think it would.
Offline robertb2700
« Reply #13 on: 21 January 2010, 19:55 »
Mainly because the door locks are on the handles? So I imagined they were connected to the locking system even though I've got remote central locking
kells
« Reply #14 on: 21 January 2010, 20:05 »
mate just do it
fark it to the theory, trues me it works :-)
Lol I may aswell just go for it, will try it on the passenger side first haha  :laugh:
can be faffy removing them, just go easy, should not take oyu long tho, it will work fiine, done mine yonks ago
« Reply #15 on: 21 January 2010, 20:07 »
On the back of the handle is a short rod that links in, but it slides out and leaves everything as it should.
« Reply #16 on: 21 January 2010, 20:14 »
This should help, no27 is the door lock now item 21 is a flat bar that pushes into the lock assembly, it slides out when you remove the handle (don't panic it is part of the ock assy.), you then fit a rear handle which has not got item 21 but the locking will still work 100%
kells
« Reply #17 on: 21 January 2010, 20:15 »
dont yank on them, the rod has a little hook on the end, one of mine broke, and i had to rob parts from anothe rhandle, and some of the handles have diff size rods,
just bear this in mind  :-)
