Author Topic: can I cut my exhaust?  (Read 1075 times)
Offline FOREST GREEN
« on: 20 January 2010, 22:51 »
Its not as bad as it sounds, I've got a '96 8v that has the standard twin pipes. They are looking a bit ropey (the 2 ends of the exhaust) so I want to fit a chrome tail pipe trim (until I can afford to get a stainless back box). My question(s) are as follows......
1. I presume that the 2 end pipes come from a single pipe just passed the back box, can I cut them off there?
2. If so, can I replace the the 2 exit pipes with a 'letterbox' type exit?
Thanks
Offline shepgti
Re: can I cut my exhaust?
« Reply #1 on: 20 January 2010, 22:53 »
anything after the main part of the back box is purley asthetic so you can chop it if you wish
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 20 January 2010, 22:53 »
should be 2 pipes from the back box (single pipe to the box, then box and 2 pipes to rear)
« Reply #3 on: 20 January 2010, 22:56 »
Any1 got any idea on what size the pipe is? i.e length & radius?
