Author Topic: Are my fuel filters dirty?  (Read 1503 times)
Offline GGGti75
« on: 20 January 2010, 21:52 »
Any help or if i could be pointed to a relevent thread i'd really appreciate it.
My poor car went to my mechanic to get a new radiator,alternater andoil pressure seal done  and after fitting them, the mechanic had problems keeping it running it idled fine but as he went to drive away, it cut out this continued idling then cutting off. He thinks its an elecrical fault, which i've never had any problems with, but i have a theory...... Through a similar incident with my mk1 15yrs ago.
The car was very low on petrol, so i'm wondering if its drawing crap from the bottom of the tank and clogging the in line fuel filters.
Please, any help or advice is appreciated
Offline roger1234
Re: Are my fuel filters dirty?
« Reply #1 on: 20 January 2010, 22:24 »
If it's a mk3 the filter is under the car in front of the rear off side wheel. More likely your mechanic has inadvertantly knocked a wire or hose.
« Reply #2 on: 20 January 2010, 22:42 »
I would suspect a electrical fault.
Offline GGGti75
« Reply #3 on: 20 January 2010, 22:52 »
Thanks for the quick replies, i'll do the in-expensive 1st, just parted with 300 quid to get the other stuff done.
« Reply #4 on: 20 January 2010, 23:14 »
Do a search, loads of threads with the same issue.
Offline Khare
  • The bear that khares
« Reply #5 on: 20 January 2010, 23:17 »
Could be ECU relay/fuel pump relay suddenly packed up. Definitely sounds electrical fault to me.
Offline GGGti75
« Reply #6 on: 21 January 2010, 08:17 »
Would my car work intermitently,this has been happening for the past 4/5 days while its at my mechanics, its now back home cause hes stumped
