Author Topic: MK3 16v problems  (Read 1560 times)
Offline aminorthreat1
MK3 16v problems
« on: 20 January 2010, 20:56 »
ok, just bought a mk3 16v(abf) its fitted with an induction kit, but when idling the car makes one hell of a sucking noise through this. its idling at about 900rpm. it also doesnt seem to be pulling too well. any ideas?
Offline VR6-Joe
Re: MK3 16v problems
« Reply #1 on: 20 January 2010, 21:00 »
Hmm sounds more like you have a split vacuum hose
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
« Reply #2 on: 20 January 2010, 21:14 »
Welcome to the site, yes sounds like a air leak.
« Reply #3 on: 20 January 2010, 21:21 »
would a split vacuum hose cause the engine to overcompensate by sucking in more air? surely this would result in higher revs? the noise is definately comin from the air filter because when i place my hand over it it stops. it also makes a hell of a noise when starting cold through the idle control valve?
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 20 January 2010, 22:58 »
Is it the correct induction kit for the car? (not universal etc) also is it a new kit? and if so check the hoses but I feel it's just the normal induction kit sound...part of the reason I don't like cones
Offline AudiA8Quattro
« Reply #5 on: 20 January 2010, 23:17 »
When i had the vr i had a k&n cone fitted for a bit.
There was a squeeling noise at about 1800rpm, i thought it was a bearing on one of the ancillaries.
After a year, i swapped back to a standard box with panel filter, the noise went and never came back.
Offline Sirminty
  • '96 16v GTI, on the lonely south coast
« Reply #6 on: 21 January 2010, 09:54 »
I've got a cone filter on my 16valve (previose owner  :angry:) and have had the same noise. Think it is just the horrible noise they make as i have checked/replaced all pipes and it is still there, :evil:
