Author Topic: 312mm front Brake calipers/carriers/Discs&pads  (Read 24630 times)
Offline Rhyso
Re: 312mm front Brake calipers/carriers/Discs&pads
« Reply #10 on: 19 January 2010, 15:34 »
With a 4 pot brake you would need no more than a 5mm spacer!
My brakes have the biggest housing out of any other 6 pot brake on the market and i only needed a 6 mm spacer!
With a 4 pot you could easily get away with a 4mm spacer! Which........ means that they do not need to hubcentric spacers! as they recommend anything over 8mm to hubcentric, anything lower than that and your ok!
So a none hubcentric spacer kit for the front, would cost around £40
not expensive!!
I was told 15mm spacer as I have Anni wheels which unless you then space out the rear would look even dafter so it does become very expensive!
A lot of the expense comes down to what you have currently fitted in terms of wheels and brakes
Offline Rhyso
Offline jake
« Reply #12 on: 19 January 2010, 15:38 »
15mm spacer???
That is ridiculous? What brakes were you going to run..... reventon brakes?
At the end of the day, people can buy what they want? But i have bought 3 sets of brakes now! The 312 upgrade was nice, as it bit a little more! yet for the money, not worth it! And dont look good under a big wheel!
Where as 4 pots..... are affordable, can be done to a small budget, not hard to get hold of... and look cracking under a wheel!
Devilz..... if you want a very cheap brake upgrade, i would say buy them! But you will be dissappointed for the money you spend!
I would recommend do a 4pot conversion in stages! Buy the calipers, then the discs etc etc. That way you dont blow money all in one go! Up to you pal!
« Last Edit: 19 January 2010, 15:40 by jake »
Offline Rhyso
« Reply #13 on: 19 January 2010, 15:41 »
15mm spacer???
The 996 rear calipers - it might be a 5mm I not 100% sure; either way I personally don't like spacers so therefore didn't pursue it
Offline jake
« Reply #14 on: 19 January 2010, 15:42 »
15mm spacer???
Fair point, but spacers to a very small scale are not expensive and not a practical issue! They space is tiny!
Offline coolio
« Reply #15 on: 19 January 2010, 15:47 »
it depend on what size wheels u got ,think it should be able to fit under 19s ... u will need the brakes lines and adaptors too
Offline Adam
« Reply #16 on: 19 January 2010, 15:48 »
Don't you just need carriers and disks for the 312mm upgrade?
Down Hill From Here.
Offline Rhyso
« Reply #17 on: 19 January 2010, 15:51 »
that you do but you can make some money back selling your old calipers  :smiley:
You can either spend time hunting the parts down or buy complete kits - up to the individual
Offline DarkGti
« Reply #18 on: 19 January 2010, 16:04 »
i will have a full set 312mm brake set up for sale soon callipers, carriers, ebc redstuff pads and ebc discs £250 all with less than 800 miles on!
sorry to hijack but will braided brake lines what are already on my mk4 fit a set of LCR brembo's?
Offline coolio
« Reply #19 on: 19 January 2010, 16:09 »
it wont fit dude !
