Author Topic: 1996 8v gti questions...  (Read 3420 times)
Offline zdebx
Re: 1996 8v gti questions...
« Reply #20 on: 19 January 2010, 21:20 »
17's alloys with 205/40/17 tyres fit perfectly with no rubbing. Got them on my car with no issues, but that is if it's standard height. So if yours is rubbing, then the car has been lowered.
Of course, if you downsize to original 15's, then everything should be ok. They are quite cheap, so you could buy them, then sell yours and get the money back or even make some :)
Have a look here >>> http://www.golfgtiforum.co.uk/index.php?topic=139980.0
« Last Edit: 19 January 2010, 22:07 by zdebx »
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Offline ronaldbiggs
« Reply #21 on: 19 January 2010, 22:15 »
Its quite starnge as it only rubs on 1 side, will have to take it to the local garage and ask them to take a look, I would not know how to tell what has been modded. Unless I can find anyone local to take a peek.
Thanks
Ron
Offline ronaldbiggs
« Reply #22 on: 19 January 2010, 22:37 »
Just a thought, could the problem be that I have recently had an avon 205/40/17 fitted and it has a wider tread pattern, could this be causin the rubbing ?
Offline zdebx
« Reply #23 on: 19 January 2010, 23:08 »
If it's only on one side, then probably the spring is the problem?
Offline boneybradley
  • Back in a Mk3...
« Reply #24 on: 19 January 2010, 23:16 »
The mk3 golf has a shell issue! Many have an offset rear axle which means the tyre on 1 side is spaced further out than the other.....It's being covered on here lots over the years
what i will say is to fit some squarer walled tyres (falken's are mean to be nice and square and that's why the saxo boys use them loads)
Offline oggy
« Reply #25 on: 20 January 2010, 08:09 »
Ron
You need to indentify the root cuase of the problem  - I'd guess a spring somewhere or possibly a knackered bush - do check rear also. Fitting standard wheels will not cure it.
