Author Topic: badly running dub  (Read 1232 times)
Offline jammac
badly running dub
« on: 16 January 2010, 17:49 »
i have a  1990 1.8 gl mk2 golf that is running like a sick dog  :sick: changed all elec components inc  plugs, leads,dis cap and arm, tried another coil  but it still doesnt tick over, tried looking to see what carb it is in haynes manual but cant  find the right one,whilst driving mid range to high revs is fine but at low revs it doesnt want to tick over, which is a right pain especially at junctions and traffic lights. so do i need a new carb or take it off and clean it, or is it something else, please help before i set fire to the f**kin thing...... bad :evil:
ITS A TRAP!
Offline Alec
Re: badly running dub
« Reply #1 on: 16 January 2010, 21:48 »
I would of said clean out the carb and and check vac hoses (dont know where they are on carb models though).
Check all the earths aswell
Failing that maybe check the coil?
Probs many other more helpful suggestions on there way when people see this post
Good luck
EDIT - Sorry didnt realise you already checked coil
Might be a bit of a long shot aswell but could have a play with the idle and mixture screws as per a haynes
« Last Edit: 16 January 2010, 21:51 by Sir Digby Chicken Ceasar »
Offline jezza16v
« Reply #2 on: 16 January 2010, 22:02 »
It probably has a pierburg carb which are tricky to sort once they go wrong (unless its been changed for a weber then it won't be in Haynes) but its more likely that you have an air leak in the thick rubber gasket between the carb and the inlet manifold, it gets sucked tight when running at higher rpm, alternatively iirc there is a short vac pipe that comes off the gearbox end of the inlet manifold and links into the servo vac pipe, this tends to get smegged & split on the underside where you can't see it, again when you give the engine some revs it sucks the split shut so OK at higher RPM but will not tickover, usually feels like its only running on 3 cylinders at idle.
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #3 on: 17 January 2010, 07:09 »
Is the corrigated pipe in good nic that goes to the manifild, I think this helps prevent the carb icing. On some cars this can be missing all together
Offline stugtd
« Reply #4 on: 17 January 2010, 12:54 »
its sounds like the idle valve is clogged to me
Offline johnson6672
« Reply #5 on: 17 January 2010, 13:08 »
also the pipe needs to be cloth not metal.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline jammac
« Reply #6 on: 17 January 2010, 17:40 »
Jezza16v - Nice one it was the vac hose you said on the gearbox side of the manifold. it had a large perished hole in it. cut a piece of coolant hose and fitted that and all back to normal! this was my mates car and he had a big grin on his face ! cheers again dude  :grin:
ITS A TRAP!
Offline jezza16v
« Reply #7 on: 17 January 2010, 18:26 »
No prob chap.  :wink:  I would get a proper bit of fuel grade hose for it as soon as you can, I botched mine with coolant hose and it went off again very quickly, killed by fuel vapour I guess.
Offline jammac
« Reply #8 on: 17 January 2010, 19:58 »
ok kool ill pass that on to him
cheers dude
ITS A TRAP!
