Author Topic: Power Steering Pumps.  (Read 1554 times)
Offline christomk3gti
« on: 16 January 2010, 01:38 »
Is there any difference to the power steering pump I.E. 8v (older engine ADY) 8v (newer engine AGG), 16v and vr6???
Need to no as i need mine changing due to a bluddy horrible squeek. which disapears for awhile when spraying WD40 around the bearing area of the pump.
My mate has a pump for me but i need to no if any will fit??
Christo
Black 8v GTI............. Whats a Waffle Valve?
Re: Power Steering Pumps.
« Reply #1 on: 16 January 2010, 09:02 »
I am guessing but 8v and 16v should be the same, I believe Vr6 is different.
« Reply #2 on: 16 January 2010, 12:39 »
ok thanks.
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 16 January 2010, 13:15 »
register at vagcat.com and have a look at the part numbers  :smiley:
Offline roger1234
« Reply #4 on: 16 January 2010, 13:39 »
Have you tried changing the belt? WD40 on the belt will have similar outcome.
« Reply #5 on: 16 January 2010, 19:35 »
http://www.vagcat.com/ excellent site.
« Reply #6 on: 17 January 2010, 13:33 »
Cheers.
I'll register.
I've tried WD40 on the belt. it didnt seem to get rid of the squeek. I think its the bearing in the pump. Hard to tell unless i have a proper look and see if there is loads of play or not at the pulley area.
Offline roger1234
« Reply #7 on: 17 January 2010, 15:05 »
Not what I meant, if the belt is worn it will squeak, spraying wd40 on the belt accidently or not will cure it but only temporarily. New belt is cheaper than a new pump and is worth trying first. If it's not the belt then a new belt for the new pump is a good idea anyway.
« Reply #8 on: 18 January 2010, 11:51 »
yeah 8v and 16v same, vr6 diffo. etka says hub spacing 41mm on vr, 52 on 8v/16v
